It is currently Sun Jun 16, 2024 2:12 am
Reply to topic  [ 9 posts ]
 RPMS, ON 36 HP PRO DRIVE!!!!! PLEASE HELP
Post RPMS, ON 36 HP PRO DRIVE!!!!! PLEASE HELP
O.K guys help me out here. I tried to tweek the motor up TO 4200 RPM'S, what the manual recommended but it seems like is idling to fast. Is around 2000 RPM'S at idle. To me it seems to fast but I really don't know!!! I put it back down to 1800 but now is at 4190 open wide. This is out of the water of course. I HAVE A 2009 MODEL(NOT MARINE) WHAT IS YOUR RECOMMENDATION, THANKS.
Fri Mar 26, 2010 6:17 pm
Post Re: RPMS, ON 36 HP PRO DRIVE!!!!! PLEASE HELP
Your idle spring and gov. spring are different. The idle screw is right next to the carb throat/air cleaner. Look between the top cover and the air cleaner (on the side of the carb). Adjust idle between 1100-1200rpm. Gov. can be set as high as 4300rpm (have my 36 set around 4250rpm) but no more or your gonna flirt with floating the valves. Set Gov. first then adjust idle.......
Sat Mar 27, 2010 12:26 am
Not much with carbs, but I can tell you that you have your adjustments off, and DO NOT take that thing out and put it in gear running 2000 rpms at idle.
Hopefully, one of these smarter fellows on here will post up and help you out on getting it adjusted right,
If not, call KP at prodrive on Monday am, and I imagine that he can help you out.....
Sat Mar 27, 2010 12:27 am
YEAH, one of these smarter fellows................... ;)
Sat Mar 27, 2010 1:11 am
What exactly did you do to it ?
Try backing off of the idle screw
Here is a digram of a 35 that may help
Sat Mar 27, 2010 10:33 am
Sat Mar 27, 2010 2:24 pm
Thanks guys for the info. I was able to get in touch with someone at Pro Drive today. Just a rookie trying to learn the ropes. Did not know there were was an idle screw. I guess I learned the hard way. Now is working fine. Today was my second day going out with my rig, I guess with practice I will get better at this. Again everyone has been a great help. :D
Sat Mar 27, 2010 11:47 pm
there are no dumb questions, ask away :)
Sun Mar 28, 2010 9:06 am
I am new to this and this is an old thread I found, but where is the governor adjustment vs. the idle screw adjustment? I am experiencing the same thing on a newer 25hp PD. Thanks in advance!
Mon Nov 27, 2017 9:22 am
Users browsing this forum: Google [Bot] and 198 guests
