longlakesd
 valve lash
How often should it be checked? 35hp gdsd 2013
| Sun Mar 08, 2015 10:37 am |
Kja0792
 Re: valve lash
Everytime u change the oill
| Sun Mar 08, 2015 10:39 am |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
 Re: valve lash
^^^ good habit to get into
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
| Sun Mar 08, 2015 11:17 am |
longlakesd
 Re: valve lash
When checking valves the briggs manual states that first you must set cylinder 1 valve 6 mm past TDC compression stroke .... what does this mean exactly
| Sun Mar 08, 2015 2:15 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: valve lash
Means put #1 at 1/4" past TDC on comp stroke prior to setting that side. Same on #2.
| Sun Mar 08, 2015 3:04 pm |
DmaxHunter
 Re: valve lash
You can also open valve cover, turn motor over by hand, ie wrench on prop nut. Watch the rockers as you turn over, one will cycle then the other. Turn slightly more until you can feel the play in both rockers. They can both be adjusted now. You can also put a wooden dowel into cylinder and watch until it starts back down off of top dead center.
| Sun Mar 08, 2015 4:56 pm |
Kja0792
 Re: valve lash
| Sun Mar 08, 2015 7:00 pm |
OwenDickeson
 Re: valve lash
http://youtu.be/Iko2izttNkESet them this way longlakesd.
| Sun Mar 08, 2015 7:03 pm |
Kja0792
 Re: valve lash
| Sun Mar 08, 2015 7:07 pm |
SETx Longtail
 Re: valve lash
_________________ #CFFITR
| Sun Mar 08, 2015 7:08 pm |
Kja0792
 Re: valve lash
| Sun Mar 08, 2015 7:11 pm |
cb5331
 Re: valve lash
| Sun Mar 08, 2015 7:14 pm |
SETx Longtail
 Re: valve lash
That's the way I set valves on every 4 stroke engine I've ever touched. TDC compression. Easy to hit with the plugs out with a wooden dowel or a screwdriver if you're careful. Roll it up, set both rockers, move to the other side.
| Sun Mar 08, 2015 7:20 pm |
SETx Longtail
 Re: valve lash
| Sun Mar 08, 2015 7:21 pm |
cb5331
 Re: valve lash
| Sun Mar 08, 2015 7:29 pm |
SETx Longtail
 Re: valve lash
hey, fair enough
| Sun Mar 08, 2015 7:33 pm |
Kcpanages
 Re: valve lash
| Sun Mar 08, 2015 8:26 pm |
Kcpanages
 Re: valve lash
| Sun Mar 08, 2015 8:27 pm |
cb5331
 Re: valve lash
| Sun Mar 08, 2015 8:52 pm |
Kcpanages
 Re: valve lash
aka new 45hp crank! Hand made! 50+ mph
| Sun Mar 08, 2015 9:05 pm |
Kcpanages
 Re: valve lash
msm8281
 Re: valve lash
| Sun Mar 08, 2015 9:11 pm |
cb5331
 Re: valve lash
That or smoking crack..
| Sun Mar 08, 2015 9:12 pm |
Kcpanages
 Re: valve lash
| Sun Mar 08, 2015 9:15 pm |
Kcpanages
 Re: valve lash
hmmm, what should I do?
| Sun Mar 08, 2015 9:18 pm |
270Handiman
 Re: valve lash
| Sun Mar 08, 2015 9:28 pm |
cb5331
 Re: valve lash
Go stand out in front of the police station and wave that thing around.
| Sun Mar 08, 2015 9:32 pm |
Kcpanages
 Re: valve lash
| Sun Mar 08, 2015 9:51 pm |
Kja0792
 Re: valve lash
| Sun Mar 08, 2015 9:57 pm |
Kcpanages
 Re: valve lash
| Sun Mar 08, 2015 10:05 pm |
longlakesd
 Re: valve lash
| Mon Mar 09, 2015 6:30 am |
Kja0792
 Re: valve lash
No watch the video again
| Mon Mar 09, 2015 6:36 am |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
 Re: valve lash
it's easier with 2 guys the first couple times you do it
_________________ that's going itch when it dries
| Mon Mar 09, 2015 6:40 am |
cb5331
 Re: valve lash
| Mon Mar 09, 2015 11:28 am |
mudxxed
Joined: Thu Sep 05, 2013 4:46 pm Posts: 1398 Location: SE Bama
 Re: valve lash
_________________ 1651 Excel/ 35 MB HD: little of dis, little of dat
| Mon Mar 09, 2015 12:50 pm |
baron von
 Re: valve lash
 - tough crowd and some dutch rudder experts here today
| Mon Mar 09, 2015 1:20 pm |
