jsar09
Joined: Wed May 13, 2009 6:37 am Posts: 14 Location: Little Rock, AR
 Pro-Drive problem
A couple of days ago I was runnin my Prodrive 27 and I was just cruising and my lower unit somehow spun thru part of the reverse cycle, about 90 degrees to the right and it nearly threw me out of the boat. I dont think I hit anything cause I was in deep water but it happened so fast that i could have . I wasnt in a turn or anything. But I dont know how it happened because I used reverse earlier that day and ran around for about an hour and nothing happened. I was just wondering if anybody ever had this happen to them? I'd like to know what happened and how to fix it or keep it from happening again before I go out again.
Tue May 25, 2010 9:51 am |
tchredneck
Joined: Tue Jan 13, 2009 7:39 pm Posts: 1812 Location: in the woods,la
 Re: Pro-Drive problem
if the t pin didnt fully set back to the forward position the lower can spin freely whenever, so if previous to this event if you used reverse that is probally what happened
_________________ 27 Contender twin 200's for sale 18x42 B.B skiff Lil daddy 36 pd Fighting da Koolaid brigade since 07'
Tue May 25, 2010 10:10 am |
mareno
Joined: Tue Mar 30, 2010 1:35 am Posts: 16 Location: Venice,La
If the 27 is like the 36. The pin is wore out. ( the one you pull to put in reverse). Maybe not but I think that could be your problem. or you did not let it go back in its place.
_________________ runninig 32.4mph in forward and 21mph in reverse with a 1860hawks fiberglass 36PD m/m & carb
Tue May 25, 2010 10:11 am |
jsar09
im guessing it is worn out, just going off of how I rode around through shallow water and grass and stuff right after i used reverse and nothing happened,
Tue May 25, 2010 10:18 am |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
I don't know how you would wear one out. But pull the pin assy apart and take a look. Pretty simple process. The holes in the reverse plate will open up some over time but after 3 years or heavy use mine is still fine. Make sure the return spring in the T-pin assy is still holding up.
_________________ 18x48 Charles Leonard / 36PD
Tue May 25, 2010 11:04 am |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
Like that dipchit mareno said, Change the pin and you'll be good to go myboy.
Tue May 25, 2010 11:05 am |
bayouboy
Tue May 25, 2010 11:13 am |
POKER1
Tue May 25, 2010 11:19 am |
Damon Silva
Give Pro Drive a call. They did have some issues with some of the units and were replaceing them under warranty.
Tue May 25, 2010 11:34 am |
bayouboy
Tue May 25, 2010 12:00 pm |
