seminole39
 Settle a debate for me please!
Will you guys please settle a debate between me and one of my buddies please? I live in East TN and I am looking into buying my first mud motor. The river where the motor will mainly used in has shallow rock shoals with water maybe 6"-8" at the most shallow parts. I am currently on the fence on which motor to choose. The only option that is a deal breaker is I want reverse. Anyway, the debate is my buddy says I will never be able to run the river with a mud motor and that I need a jet outboard.  He currently runs a 20hp Mercury jet on a 1460 jon. I do not want a jet simply because of all the maintenance involved and the pump always being clogged with debris sucked in. In your guys' opinion, could I run a mud motor in these conditions and what would you recommend as far as a motor? The motor will be going on 1648 Tracker Grizzly side console. Thanks in advance and sorry for such a long post.
Thu Jun 17, 2010 9:43 am |
SmokeEater829
Joined: Sat Jun 13, 2009 8:48 pm Posts: 1830 Location: Belle Chasse, LA
 Re: Settle a debate for me please!
A mud motor will work, but be prepared to buy a new prop every year.
_________________ Mud Buddy 4500 Black Death hauling the Uncle J 18x58
Thu Jun 17, 2010 11:13 am |
keestan31
Joined: Fri Aug 21, 2009 9:40 am Posts: 1703 Location: Groves, Texas
A mudmotor will work and I am guessing you are trying to decide between the GTR and the Pro-Drive since you commented about having reverse. Either one will work and I would suggest the 35 or the 36. If you read on here it is better to buy the bigger engine the first go around. I would suggest trying to find a dealer near you and test drive both of them.
Thu Jun 17, 2010 12:03 pm |
seminole39
Yeah I can't decide between a GTR or Pro-Drive. I'm leaning toward a Pro-Drive right now. The problem is there are no dealers for either one anywhere remotely close to me.
Thu Jun 17, 2010 12:18 pm |
Mudgun
Joined: Wed Jan 14, 2009 12:24 pm Posts: 746 Location: Here Be Rocks VA
Shit a Minn Kota would run faster than a 20 jet. Talk to me about the rivah. Is it cobble bottom, shallow riffles or sand/clay or random boulders. Unless you have random ledge rock or boulders the MM is great. Jets do clog on grass in the summer and leaves in the fall. It sucks. Get some UHMW and a Pro-Drive rock guard and you will be OK. You will learn a 250 dollar lesson your first year. It's called stay out of the sand dumbass. I'm sure there is a PD dealer in West TN somewhere.... I know it's a big state cross-ways but you can do it. Here's the kicker....jets don't run at max performance on the hull you're running anyway. You need a flat pad in front of the tunnel. 3-6° v and minimal runners. Longitudinal bracing works the same on jets as it does in MM hulls. I run a Rhino 1760 (sig is wrong) with a 90/65 Merc 2-stroke. Had a PD rig and used it a lot in the James river even in Summer flows. I wouldn't hesitate to go back. I'd have UHMW on any rig in the rocks. FO SHO.
_________________ 1660 Rhino High-Side with center console 90/65 Mercury 2 stroke Outboard jet pump Run shallow, run loud.
Thu Jun 17, 2010 4:43 pm |
jus10inla
Joined: Tue Jan 13, 2009 5:55 pm Posts: 1636 Location: Baton Rouge, LA (Central)
u said you lived in east Ten... dont know how much these will help but here ya go... TENNESSEE ABERNATHY MOTORCYCLE SALES 1704 West Main Street Union City, TN. 38261 ph# 731-885-1792 ILLOWA PRO-DRIVE HUMBOLDT, TN. CONTACT: TIM PRITCHARD BUS PH# 731-784-6602 CELL# 731-571-3183 timprit@bellsouth.nethttp://www.illowaprodrive.comILLOWA PRO-DRIVE HUMBOLDT, TN. CONTACT: BILLY WARD BUS PH# 731-784-8166 CELL# 731-697-9585 bward22@bellsouth.nethttp://www.illowaprodrive.comSOUTH CAROLINA THORNELY OUTBOARDS PO BOX 1611 MONCKS CORNER, SC. 29461 CONTACT: WENDELL THORNLEY PH# 843-761-6564 J&W Outdoors 1994 Zion Road Lancaster, SC. 29720 Contact: David Ph# 803-320-4155 Scott Ph# 803-320-0782 www.jwoutdoors.bizSouth's Finest Taxidermy and Sporting Goods 3418 W. Palmetto St. Florence, SC. 29501 Contact: David Dewitt Ph# 843-629-0771 ALABAMA C&C SOUTHERN WATERFOWL OUTFITTERS 4200 KEENE DRIVE TUSCALOOSA, AL. 35404 CONTACT: JASON RHOADS PH# 205-239-8014 PH# 205-556-5800 SOUTHERN DUCK BOATS 7004 DICKEY SPRINGS ROAD BESSEMER, AL. 35022 CONTACT: JASON RHOADS PH# 205-239-8014 PH# 205-556-5800 GEORGIA HUGGINS OUTBOARDS 922 RADIUM SPRINGS RD. ALBANY, GA 31705 PH# 229-432-6831 PH# 229-436-7676
Thu Jun 17, 2010 4:47 pm |
rebbeer
Joined: Thu Feb 05, 2009 7:39 pm Posts: 417 Location: Lafayette, LA
Not trying to start World War 3, but with a hard bottom you're prolly better off with the GTR between the 2 you have it narrowed down to.
From my experience the skeg on the pd makes it hard to get the prop down in a hard bottom.
_________________ 35 hp CDI MB HD Sport pushing a 17'6" Uncle J custom bateau
Thu Jun 17, 2010 4:58 pm |
Mudgun
You don't want to get down into hard bottom up here. It's all rock and sand. Trim it up and slide that UHMW off the cobble bar. Maybe we need carbide props like on a hammer drill.
Thu Jun 17, 2010 5:52 pm |
HUNT4DEER
Joined: Sun Jan 03, 2010 10:39 am Posts: 833 Location: DODGIN ROCKS ON THE RIVER OR CARS ON THE INTERSTATE
thats what i run all the time. same prop for over three years. the gravel doesnt really hurt the prop that bad. that mother will cut you bad from ill the little knicks but the cup is still in tact. as for the pd i think i would stick with a belt drive. the belt seems to take alot of the shock when you do hit a solid rock. i fear the pd would break a gear or the housing. a rock guard will prevent most of the prop hits. bro-in-law has mb 35 w/ guard and prop looks new. my mini 23 still runs like new. i can run with a 40 jet and the bro can way out run me. i havent found where the jets can go that i cant. price per hp is alot better also. fig my 23 hp vs. 40 hp then add the pump.
Thu Jun 17, 2010 10:39 pm |
HUNT4DEER
i just reread your post. that 20 hp boat you mention is a slug compaired to what even a 23 would do on it. as for your boat i would do a 35 if you can swing the deal. if you do your buddy will be pissed, and i bet he will want to dump the jet. has he hit any thing with that pump yet ? if not hes not going anywhere you wont be able to. when he does he will be lookin at a trip to the welding shop if hes lucky, and a new housing if hes not. you might, but not likley, need a prop, or just pull it back into the water and hit the gas.
surface drive is the way to go.
Thu Jun 17, 2010 11:15 pm |
Sand Man
Joined: Thu Jan 15, 2009 9:57 am Posts: 994 Location: Fort Worth, TX
Any mud motor is going to SUCK on a Tracker Grizzly boat.
_________________ "Fight 'em until hell freezes over. Then fight 'em on the ice!"
Fri Jun 18, 2010 7:07 am |
seminole39
Thanks alot for replies guys. I think I have made my mind up. Piss on a jet!
Fri Jun 18, 2010 7:17 am |
balloon-knot
Joined: Wed Jan 14, 2009 9:05 am Posts: 398 Location: Prairie du Chien, WI
Go with square chins and a wide boat. You will draft less water.
_________________ Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Fri Jun 18, 2010 8:31 am |
