It is currently Tue Jul 29, 2025 8:10 am
[ 6 posts ] |
I'm building adustable pods..
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
If trim tabs and pods help, wouldn't adjustable pods be the ultimate solution for planing and speed issue? I am thinking of building pods adjustable like trim tabs. Think about it... No welding to your aluminum boat or I'm my case, no bolting to hull. Pod angle fluctuates depending on need. Mais, what y'all tink? Just have to beef up trim cylindar or double up per pod.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Sun Aug 15, 2010 7:07 pm |
whitelightning
Joined: Thu Mar 26, 2009 1:53 pm Posts: 77 Location: DE, MD, NJ
 Re: I'm building adustable pods..
Interesting. How do they attach to the boat if they are not bolted or welded? Would they be able to hold up to the bouncing over waves at 20-30mph?
_________________ 1544 G3 with 23hp GDLT
Sun Aug 15, 2010 10:57 pm |
quackconsumer
Wouldn't it be cheaper to just sell da boat and buy one dat is designed for da motor?
Mon Aug 16, 2010 4:36 am |
dguidry
Hinged to the transom just like trim tabs with compression cylinder to alow flexing.
Mon Aug 16, 2010 7:05 am |
dguidry
Mon Aug 16, 2010 7:10 am |
dguidry
Any engineering types out there care to comment how I might handle lateral and torsional (twisting) forces on the pods while in motion? Also, how to handle gap between pod and transom when pod is deployed downward. Flow of water from side of hull would hit the back of the pod. I thought the solution would be an aluminum extension to the side of the transom inside of which the pod would move back and forth...sort of like a pocket. My plan is to buy large aluminum trim tabs with the hinge attachment and fashion the pod to them, altering the tab where needed to conform to the pod shape. My research indicates I have to be cognizant of the turbulence created by the pods in relation to the prop and skeg. Mais, what ya'll tink?
Mon Aug 16, 2010 10:06 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 104 guests |
