hounddog
 Help
just bought a 1652dk g3. I am thinking about putting a 36hp pro-drive on it,how will it preform on this boat or is there something else that would do better.
Tue Aug 24, 2010 9:17 pm |
LA Mudder
Joined: Wed Oct 21, 2009 9:18 pm Posts: 422 Location: Belle Chasse, LA
 Re: Help
i think fowl habit has that boat, wait for him to chime in
_________________ 18x58 w/healthy GTR 35 "A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Tue Aug 24, 2010 9:32 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: Help
be careful......test drive it prior to buying.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Tue Aug 24, 2010 9:49 pm |
Mud Slinger
MMT Moderator
 Re: Help
check out the review forum viewforum.php?f=5
_________________ duck wacker
Wed Aug 25, 2010 11:55 pm |
hounddog
 Re: Help
Ok got the 36 pro drive put on my g3 1652. I bought it used,so I took it out for the first time and coudnt get it to plane out the boat. I took the motor back to the dealer and he said that it should run good on the boat. We looked at the prop and it was wore out,so put on a another one off of a used motor that was a lot better and it is a lot better. Got 24 mph out of it,is this what I should expect or should it get more
Sun Aug 29, 2010 11:04 am |
cb5331
 Re: Help
I would think you could run a lil faster than that, but it is a heavy hull designed for an outboard. Get some stick time, play with the weight in the boat, and the trim. You may have a couple mph hidden somewhere, but probably not much more than that.
Wonder how it will do when you load it down for hunting...
Sun Aug 29, 2010 2:52 pm |
OwenDickeson
 Re: Help
Sun Aug 29, 2010 2:54 pm |
jn70549
 Re: Help
Sun Aug 29, 2010 3:00 pm |
hounddog
 Re: Help
I did read the post to my question. I did try it out before buying,for i have the right to take it back. I am happy with what it is doing,just asking some of you (pro's) if i should get more. Thanks to all who gave helpfull advice and to those who are negative sorry you read my post.
I am a believer in longtails,and have had both. The longtails will go where these fast surface drives wont. Speed isn't my most concern,but i like the easy use and control of these motors. I have never had a surface drive this big so just wanting some expert advice.
Sun Aug 29, 2010 5:59 pm |
LA Mudder
 Re: Help
yes most stock rigs on here average in the 27 to 29 mph range
Sun Aug 29, 2010 6:08 pm |
OwenDickeson
 Re: Help
Sun Aug 29, 2010 11:02 pm |
jordy
Joined: Thu Mar 11, 2010 8:25 pm Posts: 1588 Location: South Louisiana
 Re: Help
Fri Sep 03, 2010 2:00 pm |
