It is currently Wed Aug 06, 2025 12:13 am
Reply to topic  [ 27 posts ]
 one or two battries
Post one or two battries
I have a 35 GTR and was told not to run a spot light on the same battery as the motor because it would burn up the charging system. How do yall run a spot light ? Do i have to run two battries
1546 Triton with 35 GTR
Thu Mar 26, 2009 6:14 pm
Post Re: one or two battries
I run the motor on original batt; all other accy on second. Something about the motor not charging until 2000 rpm's. I believe minimal accy usage wouldn't be too bad, but wouldn't you rather know you're getting home one evening. Remember, no rope start :?
Ace
Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Thu Mar 26, 2009 7:06 pm
yea getting home is important. The problem i have is i leave my boat in the water over night and not able to charge battery without removing it and bringing to camp. With my outboard i could run all weekend and keep my battery charged. Also dont want two battries in boat
Thu Mar 26, 2009 7:15 pm
Well then take your chances that you won't use more than you can charge. Like I said, small usage at times prolly won't kill it, but the GT dudes told me to get a second batt for my lights. I run two aircraft landing lights in the front, and I have a hardhat light that I use also. Usually not together, but for froggin, we idle a lot and use the hh light alot. Don't take the chance on only one batt. Good Luck :D
Ace
Thu Mar 26, 2009 7:19 pm
If you're coming to GT appreciation days, then you can talk to the FE's 8-)
Ace
Thu Mar 26, 2009 7:20 pm
I got 2 batteries and my 23 gotta rope start! :mrgreen:
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Thu Mar 26, 2009 7:22 pm
Get a lawn tractor battery for a back up.
18x48 Charles Leonard / 36PD
Thu Mar 26, 2009 7:27 pm
how good will a small battery hold up just for a light
Thu Mar 26, 2009 7:30 pm
I have run my 36PD on a lawn tractor battery for over 18 months with no problems. Its a 425ca battery from Auto Zone. That includes using the running & HH light for several hours at a time frogging. I carry second battery up front for a spare just in case and for a second HH light. So a standard battery for the motor should be fine.
Thu Mar 26, 2009 7:37 pm
Ace i see your from Lafayette thats where i work most of the time.
Thu Mar 26, 2009 7:51 pm
The thing is the clutch draws 20 amps and the altanator charges 20 amps so you kinda at a stand off. I run a headlight and do fine but maybe with two you might have problems . Instead of a second bat. go to wall mart and get you a jump starter pack for 35$ and keep it in your boat never have to worry about a dead batt. and only weighs a couple pounds
17x48 extreme stage 2 GTR
Thu Mar 26, 2009 8:04 pm
Some of you boys think bout this shit way to much. I been running the same wal mart battery for the past 5 years on a mud motor, used two lights froggin for a couple hours many times with no problems whatsoever.
It's a fuking lawnmower engine
Pro Drive m'fers
Thu Mar 26, 2009 8:10 pm
Thu Mar 26, 2009 8:22 pm
Thu Mar 26, 2009 8:27 pm
Thu Mar 26, 2009 8:37 pm
I would hate to be tranded too. :lol: Thats why I carry a second. They don't weigh much and its good piece of mind since there is no pull starting this thing.
Thu Mar 26, 2009 8:48 pm
Thu Mar 26, 2009 9:05 pm
I put it in the battery box under my extended deck where its strapped down. Same place the TM battery goes.
Thu Mar 26, 2009 9:20 pm
Man I hope I never get tranded :lol:
Terry, if I get tranded will you come help me?
Preston, try not to get tranded :lol:
Pro Drive m'fers
Fri Mar 27, 2009 7:26 am
All may Accessories ar off the cranking battery. Ran all duck season with my HH light on that battery. But then again I was wide open so charging is not the issue. Common sense tells you an alternater dont put out much juice at idle. Thats when you need a second battery IMO.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Fri Mar 27, 2009 8:12 am
I made something that works to get you out of a bind, get a cordless drill from Harbor freight take the battery out and hook up wires where the battery connected. You have to make a handle for the chuck side and when you crank it with the trigger pressed it will charge your battery enough to get it to start, you never have to worry about your back up battery being dead. found the info here on how to do it!
http://www.zetatalk.com/energy/tengy05n.htm
There is no replacement for displacement!!!!
Fri Mar 27, 2009 9:53 am
Fri Mar 27, 2009 10:44 am
Pro Drive m'fers
Fri Mar 27, 2009 10:45 am
Fri Mar 27, 2009 10:58 am
At best the motor will maintain your charged battery. Charge your battery at home every now and then is a good idea. Make sure your starting your trip with a good battery to begin with.
Fri Mar 27, 2009 11:10 am
Get you a squirrel and a wheel and hook that up to a small generator.
Then you won't have to worry about the charging system of the motor.
Fri Mar 27, 2009 11:39 am
But you got to have nuts!!!
Fri Mar 27, 2009 11:40 am
Users browsing this forum: No registered users and 90 guests
