It is currently Mon Jul 28, 2025 2:03 pm
Reply to topic  [ 26 posts ]
 Pro-Drive load up?
Post Pro-Drive load up?
When in mud my prodrive seems to loose thrust. Reading in the owners manual it mentions something about "load up" when trimmed down in thick mud. It's really freaking aggrivating. Any of you goys that have been running prodrives for a while have any insight on the best way to handle it.
BTW, I'm running a 16" motor on a 22" transom. I realize that it is really limiting my motors performance, and most definately in the mud. With it not being able to really reach down deep in the mud it would seem that the load up- if it what I think it is- would not be as severe.
"You may all go to hell, as for me I'm going to Texas" D. Crockett
What is best in life?
To crush your enemies, to see them driven before you, and to hear the lamentations of their women.
Mon Nov 01, 2010 3:17 pm
Post Re: Pro-Drive load up?
Not sure exactly what your saying but I run a 32hp PD on a 1648 gatortrax and ive never had any problems with the thick stuff. It does "bogg" down some but thats when you just floor that Bi**H and roll on. Your motor/boat combo might be the problem but like I said I can really only speak for my rig and ive never seemed to have any problems. you got any more info? like explain more specifically what is going on. is it acting like its gonna kill?
Sold my Uncle-J and my PD so Fuc* Y'all!!!!!.
"THE EDGE: There is no honest way to explain it because, the only ones who know where it is have gone over. The others... the living, are those who've pushed their control as far as they felt they could handle and then pulled back or slowed down........BUT the edge is still out there...."
Mon Nov 01, 2010 4:43 pm
I know that the shaft is to short. It's not bogging down, it's loosing thrust.
Mon Nov 01, 2010 5:04 pm
I think you answered your own question. Cut the transom or go long shaft. I would do the latter.
18x48 Charles Leonard / 36PD
Mon Nov 01, 2010 5:30 pm
I dosent have anything to do with the transom length.
Does anyone know what "load up" is or what causes it and how to prevent it? It's like my prop isnt turning as fast as it should at WOT. It's like the clutch is allowing alot of slip. It's not constant and only happens in thick stuff sometimes.
Mon Nov 01, 2010 5:43 pm
Id guess its the added resistance added by what ever your running in. You have a limited amount of power so there is no way around it without adding HP. I have never heard of anyone talking about it before. But if your running a short LU on a tall tranom hull there is no way your getting the performance that you should be getting.
Tue Nov 02, 2010 10:25 am
Tue Nov 02, 2010 11:12 am
rpm's arent dropping. just the amount of water and mud being moved behind the prop.
Tue Nov 02, 2010 11:17 am
IMsO ~ You ain't gonna be no-where rite with a short engine runnin' on a tall engine transum. It just ain't gonna happen.
Tue Nov 02, 2010 1:21 pm
Tue Nov 02, 2010 2:38 pm
Why don't you call KP and ask him? I'm sure he'll tell you exactly what that means.
Tue Nov 02, 2010 2:48 pm
Tue Nov 02, 2010 3:23 pm
Its not hard at all to drop the lower unit down. Doesn't take much time at all. I can't speak for changing out the shaft. But I had to drop mine to install my reverse and it didn't take 10mins.
My motor doesn't have docking assistance, it has REVERSE!
Tue Nov 02, 2010 7:09 pm
I think that there is some welding involved.
Tue Nov 02, 2010 7:11 pm
You have to weld the 4 inch spacer onto the saddle. No change in shaft. Its just an extended spline coupling.
Tue Nov 02, 2010 7:23 pm
I didn't think you had to weld it..
But if you do, pm willet and see if you can hook up with him. I am sure he would do you right on price... He is in your area....
I would go with adding tall transom bracket to that motor long before I would cut that transom down.... regardless of cost or ease..
Also, don't know what you mean by "loading up". It normally means you carb is loading up (too much fuel) and you lose power.
That is not a standard prodrive issue as far as I have ever seen and we run two of them, and have been around a bunch more. Have never had that problem or heard of it.
If it is in fact the motor (and not the way you are running it-stick time is important-don't know your experience level and don't mean to demean it if you have a lot-but i have even seen video posted on here of guys who weren't running it right when getting it unstuck in the mud-there is an art to it) then you have something wrong with you motor. I would start running that down.... Fuel/air/spark. Simple first.
x2 on as long as you have a short transom motor on a tall transom boat, you will never really run right and therefore won't know what is going on....
Good luck and keep us posted.
Tue Nov 02, 2010 8:41 pm
Footnote: Should your engine load up (lose power) while trimmed down in the
Above conditions, trim up using the hand wheel until the engine is
running normally again.
as per the pro-drive owners manual.
What does it mean?
Tue Nov 02, 2010 8:51 pm
It means your bogging that big prop down in thick chit. Push down on the tiller to free the prop some so it spin back up to higher rpms. These motors don't have the kind of power needed to keep the prop at full rpms in thick stuff if you have the LU buried to deep. As stated with a little time on the motor you will be able to feel things out. It is nothing to worry about and any of these motor will loose rpm and thrust in those conditions. Trimming up will also free up the LU but you can do the same by pushing down on the tiller and will find in time that the wheel sucks....... In the harder bottoms we have up here you will find that hydro trim worth its weight in gold.
Tue Nov 02, 2010 8:56 pm
sounds like joe aint got the commonsense of a jackass.
get you a pirogue and a paddle,easier to operate. :lol:
Tue Nov 02, 2010 11:50 pm
Wed Nov 03, 2010 3:54 am
Wed Nov 03, 2010 3:56 am
Wed Nov 03, 2010 5:22 am
I changed over my PD from short transom model to long transom and yes, I will confirm that you have to weld on the extension. Other than that, the whole process a piece of cake that could easily be performed with basic tools.
Each of these short tail mud motors has specific drive lengths and angles incorporated into their designs. Until you convert to the long transom configuration for your tall transom boat you will never achieve the motor's full performance capability.
Just get a buddy with a welder (remember, it's aluminum) get yourself half rack of beer and get'r'done. :mrgreen:
Sun Nov 07, 2010 1:05 pm
Sun Nov 07, 2010 1:23 pm
yes you have to weld them on now days
in the beginning you didnt have to
its an easy fix joe you know my number
as for "loading up" like poker said up here its gonna do it big time because its not true mud like down south
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Sun Nov 07, 2010 4:08 pm
Willet, I'll holla.
JC, :middlefinger:
Sun Nov 07, 2010 6:22 pm
Users browsing this forum: No registered users and 169 guests
