It is currently Mon Jul 28, 2025 2:01 pm
Reply to topic  [ 14 posts ]
 determining connecting rod length
Post determining connecting rod length
i just bought a motor that has evt connecting rods, and am trying to figure out if theyre the stock length or not because i am going to sell them. mike at evt said the longer ones would only be used on shaved pistons, but they dont appear to be shaved. yeah i know it seems to answer my own question, but this motor has every part evt sells/sold and cant imagine that they changed everything BUT the pistons. i just dont wanna sell somebody these thinkin they are factory length and they install them and cause damage. is there a way to measure them?
thanks,Rod
Tue Nov 30, 2010 5:53 pm
Post Re: determining connecting rod length
With a ruler
Wed Dec 01, 2010 7:44 am
There are enough folks on here with blown up motors they can measure a stock rod for ya. You need something more accurate than the ruler ur 3rd grade teacher gave ya.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Dec 01, 2010 7:49 am
http://www.ehow.com/how_7447171_measure ... ength.html
Wed Dec 01, 2010 8:00 am
The most common reasons for using a pushrod that is longer or shorter than stock are: a decked cylinder block or heads, thicker/thinner head gaskets, small base-circle camshafts, aftermarket rocker arms, longer-length valves, valve jobs with varying seat depth, non-stock lifter designs and/or seat height, and converting to an adjustable valvetrain. These variables inevitably alter pushrod length; however, following these easy steps will help prevent improper geo-metry and ensure your engine's longevity.
Zero out the Comp Cams pushrod length-checking tool,
( http://www.summitracing.com/parts/CCA-7709-1 ) then install it in the lifter's pushrod seat and within the pushrod guide plate on the cylinder head (if applicable).
If your camshaft requires valve lash (our mechanical roller cam calls for 0.012 inch), insert the proper feeler gauge between the rocker-arm tip and the valve tip.
If the rocker-arm tip is beyond the 11/43-forward position, you need to return the lifter to the cam base circle, shorten the adjustable pushrod, and slightly loosen/tighten the rocker-arm adjustment nut (changing the initial 11/43-forward position). Next, readjust the checking-tool length so that it achieves zero lash on the backside of the rocker arm. Then roate the engine through its firing in order to note movement range of the rocker-arm tip.
While holding up the pushrod end of the rocker arm, turn the rocker adjustment nut so that the rocker-arm tip is approximately at the 11/43-back position on the valve step tip. Note: the more you tighten the rocker adjustment nut, the further it moves the rocker-arm tip toward the 11/43-back position.
Rotate the engine through its firing order to open the valve as cam lobe increases. Stop when the cam lobe is at maximum lift. As the lobe lift increases, the rocker arm should move toward the opposite side of the valve tip (the 11/43-forward position).
Note how many turns out from zero the tool is. For each 360-degree rotation of the threaded end (adjustment amount indicated by thin white lines), add 0.050 inch to the measurement. For example, this checker tool (PN 7994-16) has a 7.80-inch length when zeroed out. To that we added three turns out (0.050 inch x 3) from zero, which brought us o a final length of 7.950 inches.
Wed Dec 01, 2010 8:08 am
:o :shock: :o :shock: :o :shock: :o
on Uncle Js !!!!
But ~ Somehow .... I knew it !!!! :lol:
Wed Dec 01, 2010 9:23 am
Push Rods???? :roll: :roll:
Wed Dec 01, 2010 10:00 am
I thought we were talkin bout connectin rods?
Wed Dec 01, 2010 10:05 am
Bayou Surface Drive
337-351-0362
Wed Dec 01, 2010 10:39 am
nice try J, but yes, i am talkin bout connectin rods
Wed Dec 01, 2010 10:40 am
sorry.. I was just trying to be a Smart Azz in a very short time..
Wed Dec 01, 2010 10:44 am
Wed Dec 01, 2010 11:00 am
What's the wristpin diameter?
Thu Dec 02, 2010 10:30 am
nevermind guys, stock length
Thu Dec 02, 2010 9:04 pm
Users browsing this forum: No registered users and 169 guests
