It is currently Mon Jul 28, 2025 4:57 am
Reply to topic  [ 9 posts ]
 Long Tail Mod
Post Long Tail Mod
Ok guys, now that the season is pretty much over here in Mississippi, im using the time to work on a motor I picked up. I plan to cut this 8hp go devil long tail down to size for timber use. What will i need to do with the cav plate, and the skeg and all once i trim the shaft down. Also how should i do these bushings up?
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Tue Jan 25, 2011 4:30 pm
Post Re: Long Tail Mod
Put everything back the same. Make sure to measure the cavitation plate angle before you cut it off. I know it can be a pain in the woods with the longer shaft but I would leave it long cause it sure is nice to have some reach when the ass end is a foot and a half out the water stuck on a log. Just my $0.02
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Tue Jan 25, 2011 5:37 pm
Its gunna have a steep angle on a 16 in transom.... You gunna cut it down?
Tue Jan 25, 2011 8:31 pm
Tue Jan 25, 2011 9:54 pm
Its at 13 inches now not sure how much shaft to take off to get it to run propper.
Tue Jan 25, 2011 10:24 pm
A 72" shaft on a 16" transom has a rise over run of 4.5", On a 13" transom a 58.5" shaft would have the same angle.
On another note, Go-devil crawfish models have a 58" shaft on a 16" transom so a 13" could have a 47.125 shaft at the same angle, If yours is a 72 inch shaft you will need to reposition the the drive tube at a steeper angle with a steeper u-joint to have a more horizontal engine and a better trim range. Dont get it too short/steep or you will start breaking u-joints and have a bad in the water angle.
Wed Jan 26, 2011 7:28 pm
So how short should I go woodie to get to 12 or 13 inch transom
Fri Jan 28, 2011 10:52 pm
What is your shafts current length?
Sun Jan 30, 2011 8:13 pm
Its 72inchs now and the transome is 15 inches tall, im just lookin to see how much i can take off for gettin around in the timber.
Tue Feb 01, 2011 10:27 pm
Users browsing this forum: No registered users and 98 guests
