It is currently Sat Jul 26, 2025 10:29 am
Reply to topic  [ 8 posts ]
 PD HYDRO TRIM INSTALLATION
Post PD HYDRO TRIM INSTALLATION
NEED A LITTLE HELP HERE, do you think MY X2 PRO DRIVE BOAT transom has enough room to install the pump without offsetting it to the side.Is a 2009 model. Since I don't have a brace in the middle I was told I may have to offset or weld one. Thanks for the help.
Thu Sep 29, 2011 4:51 pm
Post Re: PD HYDRO TRIM INSTALLATION
That brace looks low enough, but it's hard to tell. We had to offset on my dad's last boat, but the hoses they came with were long enough. Wasn't a big deal.
Thu Sep 29, 2011 4:59 pm
looks like you have room.
Thu Sep 29, 2011 5:03 pm
i would try to put it under the corner brace out of the weather and sun plastic will last a lot longer that way
driving a gd in ur lake
and i aprove this message
Thu Sep 29, 2011 5:06 pm
yes anyone of the vertical channels is where they install them.
35gtr Stage 1 On 19'3"x46" Mad man Hull going Places far and beyond
Thu Sep 29, 2011 6:29 pm
Does the pump just install on the PD bracket where the pre drilled holes are at? Or do you also bolt it on the boat? If it needs to be offset do I use self tapping screws to put on the brace. Thanks for the help again.
Thu Sep 29, 2011 8:56 pm
18x48 Charles Leonard / 36PD
Thu Sep 29, 2011 9:09 pm
I got a measurement of 13.5 in of clearance from where you bolt the trim on the motor to where the middle brace starts (see the pics).Can someone give me a measurement of the entire unit. I think I was told I needed a 12 inch clearance? I just want to verify, before I ordered it, thanks again!
Fri Sep 30, 2011 8:34 pm
Users browsing this forum: No registered users and 99 guests
