It is currently Mon Aug 04, 2025 11:51 pm
Reply to topic  [ 7 posts ]
 GTR Reverse
Post GTR Reverse
OK so we went frogging Fri. nite, noticed reverse lever was really low. Suspected low fluid. Small town near camp, could only find DOT 3 brake fluid. Filled reservoir with DOT 3, reverse lever came back up, worked fine all nite. What damage have I done with the DOT 3? Should I flush the system and replace with DOT5? What should I use to flush if so?
Ace
Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Sun Aug 16, 2009 8:44 am
Post Re: GTR Reverse
i dont know what kind of damage u did if any . u can flush it with new fluid
Sun Aug 16, 2009 9:31 am
Profile YIM
Sun Aug 16, 2009 12:52 pm
DOT 3, DOT 5, Does it really make a difference????
Sun Aug 16, 2009 1:51 pm
OK, so to close up this post. Called Hoyt this am and he said it most likely had DOT3 from GT when I bought it. He tells me that they will most likely be changing the manual from DOT5 to 3.
Shouldn't be a problem, but I did see on the www where you can't mix the 5 with the 3. Causes some kind of gelling problem. Anyway, I didn't do any damage to my Reverse :D
Ace
Mon Aug 17, 2009 9:49 am
kool good deal
Mon Aug 17, 2009 9:50 pm
Profile YIM
If I remeber right the only difference is temp rating between dot 3 and dot 5.
Tue Aug 18, 2009 8:08 am
Users browsing this forum: No registered users and 131 guests
cron
