It is currently Sun Jul 20, 2025 3:56 am
Reply to topic  [ 11 posts ]
 Hydroturf problem
Post Hydroturf problem
Putting hydroturf down and using the 3m 90 hi- strength spray adhesive, then going around with contact cement around edges. I'm having a problem with it bubbling in the middle, am I not letting the spray adhesive tack long enough? And in these spots what can I do to fix?
Tue Mar 12, 2013 8:40 pm
Post Re: Hydroturf problem
Also what can I put to keep seams together and tight?
Tue Mar 12, 2013 8:41 pm
It should be dry, not tacky, when you lay it down.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Mar 12, 2013 9:24 pm
You have to put it on both surfaces, wait till it dries, then once you put it down, it ain't coming back up.
Tue Mar 12, 2013 9:26 pm
I did put it on both, guess I'm not waiting long enough for it to dry
Tue Mar 12, 2013 9:30 pm
Weldwood contact cement in the green can.
Sent from my DROIDX using Tapatalk 2
1850 & 36pd
Tue Mar 12, 2013 9:32 pm
With it bubbling up take your razor and make a small cut in the middle of the bubble. Then work the outside of the bubble to the inside pushing it down. Once it's all pushed down you won't be able to see the cut
WC 1848 Bateau w/ 36 PD FPR
Tue Mar 12, 2013 9:41 pm
Use the right amount of dry time. The adhesive is still off-gassing.
Tue Mar 12, 2013 9:49 pm
1850 & 36pd
Tue Mar 12, 2013 10:00 pm
2011 3 Man Gator Hide
10' MB 7000
Zoom, Zoom
Fri Mar 15, 2013 12:20 pm
I did.
Sat Mar 16, 2013 5:16 am
Users browsing this forum: Google [Bot] and 122 guests
cron
