It is currently Mon Aug 04, 2025 12:47 pm
[ 8 posts ] |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
 Want to trim higher
I need to be able to trim up a little higher due to the fact I have a 20 degree transom with a PD. I have only had the problem a couple of times really loaded down but I can trim down way more than I would ever really need to.
I was told there is a larger roller (not sure thats the right name) that I can use with the hydraulic trim to accomplish this. Basically I need a piece of rubber tubing to replace or slide over my existing roller. I will probably just order one from PD since I'm lazy but I wanted to know if this was something readily available at a hardware store and what size. I can't remember what I was told, so I figured I would ask. Has anyone done this easily in order to change the trim angles? Thanks.
Thu Oct 22, 2009 1:11 am |
Swamp Wader
 Re: Want to trim higher
you could use a shim or wedge on the transom
Thu Oct 22, 2009 5:21 am |
yak
Joined: Sat Feb 14, 2009 8:25 am Posts: 80 Location: Assumption Parish
Wilson-let me know what you find out about this. I'm kinda havin the same issue.
_________________ 18/44 Blanchard Skiff 36 Prodrive-FPR-T&T
Thu Oct 22, 2009 8:50 am |
Wilson
Thu Oct 22, 2009 9:22 am |
J Wales
I don't think you can do this with the hydraulic trim. The arms that connect the roller to the hydraulic ram are different than on the manual trim. Basically, the new arms take the extra play out, so that you have the full range of motion with the hydro trim. If you had a larger hose or a spacer, you would not be able to get it to fit around the current hose/roller.
_________________ 1848 Brother w/ 36 PD
Thu Oct 22, 2009 11:49 am |
Wilson
I'll have to look at it when I get home. I'm just going by what PD told me. Maybe I wasn't clear enough with them but I thought we were on the same page.
Thu Oct 22, 2009 11:51 am |
b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
mount you a little gill bracket on the back of your boat!!!
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Thu Oct 22, 2009 2:32 pm |
squirrel
as swamp wader stated (shims). go to any outbord shop pick up a set of shims bolt them on. its that easy . if u take your time and drink a couple beers it should still take less than 30 min.
Thu Oct 22, 2009 3:17 pm |
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 118 guests |
