It is currently Sun Aug 03, 2025 11:04 am
Reply to topic  [ 13 posts ]
 U-joint removal
Post U-joint removal
does anyone know how to get the u-joint off of the shaft. I'm trying to take the engine off of a go-devil longtail.
"You may all go to hell, as for me I'm going to Texas" D. Crockett
What is best in life?
To crush your enemies, to see them driven before you, and to hear the lamentations of their women.
Wed Jan 06, 2010 3:05 pm
Post Re: U-joint removal
if you are trying to take the joint out of the yoke, you need to know out the C-clips and then use sockets and a hammer to know out the joint. Good luck. Ince you look sat it youll know what to do.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Jan 06, 2010 3:15 pm
Thats a good querston !!! I figure you could just undo the engine mountin' bolts and pull it away from the shaft ... I don't know fo sho !!!
Wed Jan 06, 2010 3:16 pm
man that things givin you hell aint she??! just be sure not to pull directly against the shaft. if you take the yoke apart you should be able to use a puller or something to get her off. good luck. them things can get all kinds of seized up! :evil:
ETD88 09/28/09-05/14/2010...
Wed Jan 06, 2010 3:22 pm
I've un bolted the engine, taken the set screws out of the u-joint, beat the fu(k out of it with a hammer and broken a punch. Theres gotta be a better way!
Wed Jan 06, 2010 3:27 pm
u may want to take the yoke apart so you can get the engine in a better position, off the frame. then youl have a lot more room to work with.
Wed Jan 06, 2010 3:30 pm
Can you like put a pully puller 'round it ?
Wed Jan 06, 2010 3:42 pm
Go rent a balljoint press and you will thank yourself. You will need a 7/8" socket and an impact wrench and go to town.
Bayou Surface Drive
337-351-0362
Wed Jan 06, 2010 3:44 pm
I'm about to go rent a cuttin torch and make me some trot line weights!
Wed Jan 06, 2010 3:55 pm
Wed Jan 06, 2010 3:59 pm
Location: In a trailer of common sense, looking out the window at a tornado of stupidity
Wed Jan 06, 2010 4:25 pm
VICTORY!!! thanks, capn j.
Wed Jan 06, 2010 5:13 pm
NICE Job Capt on that .... have you showed yore son that trick yet ??
:lol:
I thot he was tryin' to git the yoke off the engine drive shaft is what I thot ...... what a dumb-butt reader I am ...... :oops: :lol:
Just another way us MMT fellers jump in there and help .... short-tail .. long-tail ... and in some cases ... soft-tail .... we are here to help !!!!
:lol:
Wed Jan 06, 2010 7:44 pm
Users browsing this forum: No registered users and 160 guests
