latravcha
 running lights
Im on my second rear running light of the season. I keep breaking them off while in the woods. I have seen a few boats that have lights attached to the air box on the motor. It seems like this would be a better set up. Has anyone rigged up like this and how did you do it A picture would be great
_________________ Aucoin 20X48 36pd Lock your wife and your dog in the garage for an hour. Then open it and see who's happy to see you.
Fri Jan 08, 2010 10:18 am |
WestEndAngler
MMT Moderator
Joined: Thu Mar 05, 2009 9:11 am Posts: 9143 Location: Houston | Surfside
 Re: running lights
_________________ GTB 1860 w/ 2019 GTR40XD-HO
Fri Jan 08, 2010 10:21 am |
MaXXis85
 Re: running lights
Or take you the normal metal stern lights.. Cut it with a pipe cutter and put some rubber hose to sleeve it with. Then hose clamps to hold the rubber to both sides of the posts. then hit all you wand and it will bend out of the way and pop back up.
Fri Jan 08, 2010 10:48 am |
EasTexDux88
Joined: Tue Sep 29, 2009 3:08 pm Posts: 1069 Location: Longview Tx
 Re: running lights
_________________ ETD88 09/28/09-05/14/2010...
Fri Jan 08, 2010 10:57 am |
MudHog
Joined: Thu Sep 24, 2009 7:32 am Posts: 154 Location: 70560
 Re: running lights
are you talking about the anchor light? Just take it off. If your in LA, don't need it on until your anchored.
Fri Jan 08, 2010 12:04 pm |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
 Re: running lights
take that pole off when you get to the woods! game warden isn't going to see you off in the woods, and I seriously doubt you're at risk of collision with another boat.
_________________ 24x60 Dual Prodrives
Fri Jan 08, 2010 12:08 pm |
Capt Jeff Kraynik
Joined: Thu Jan 15, 2009 3:48 pm Posts: 102 Location: Florida's Space & Treasure Coasts
 Re: running lights
I've had mine mounted on top of my air cleaner for years.
Directly underneath the cover I placed a quick disconnect plug so it's not just hanging there when servicing the engine.
_________________ If your courage holds, luck will get you through most situations!!!
Fri Jan 08, 2010 12:10 pm |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
 Re: running lights
_________________ 18x48 Charles Leonard / 36PD
Fri Jan 08, 2010 12:40 pm |
WestEndAngler
MMT Moderator
 Re: running lights
Poker I know the law in TX states running lights on bow (green / red) and 360 white light on the stern while underway. Now if your at anchor you can turn off the NAV lights (Green / Red) but must leave the 360 degree stern or anchor light on.
Fri Jan 08, 2010 1:19 pm |
craig
 Re: running lights
Fri Jan 08, 2010 1:20 pm |
MudHog
 Re: running lights
I do stand corrected as I just got an explination from Wildlife and Fisheries.
Yes, when underway you are required to show a white light, as well as, the red/green lights. When anchored, you only have to show the white light. In the regs this white light is the same as the anchor light, just described with words two different ways. I was actually taking the quoted statment above as having a light available and not neccessarily turned on. Now I know.
I can't say how many times I've left a landing with just the red/green lights showing and have never had any problems. I've always had a q-beam available to see, just never a light always shining. I've even came into the landing with wildlife and fisheries there and never once got questions about the white light.
I'll now have a white light on when under power.
Fri Jan 08, 2010 3:01 pm |
POKER1
 Re: running lights
I use mine till I get to the thick stuff and then remove it. Always have my HH light on at night.
Fri Jan 08, 2010 3:11 pm |
