It is currently Sun Aug 03, 2025 11:02 am
Reply to topic  [ 6 posts ]
 length or width?
Post length or width?
what makes a boat better at carrying a load? IE what will carry a load better with a 35 GTR a 16x60 or 18x 48?
Fri Feb 05, 2010 8:09 am
Post Re: length or width?
I think that lenth will make for the most load carrying ability.
Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Fri Feb 05, 2010 10:20 am
Different people will have different opinions on length or width. OHHH were talk bout boats.. nevermind LOL :lol: :lol:
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Fri Feb 05, 2010 11:25 am
girth is not a direct substitute for length :o
Fri Feb 05, 2010 11:38 am
My experience would be that it depends on your application and what you are trying to accomplish. I have had both.
As stated already to carry more load, I would go length. If I wanted side to side stability with less load, I would go with wider boat. You have to define load... 2 guys, dog, dec's, gear? or 3 or 4 guys, dog, dec's, gear?
Also depends on your motor... If the load I was referring to was the motor, I would go wide to get more displacement at the rear. If it is people and things that you can spread out thru out the boat then longer is better.
If you are having the boat built, I would discuss with the builder-depending on who it is, those guys know what they are doing-they do it everyday
She said get longer and wider....
Fri Feb 05, 2010 11:51 am
Both length and width contribute to boat's load carryin capabilities. It's all about water displacement vs. drag, and da more surface area at da bottom of da boat contribute to both of dem. Da goal is to find a happy median. If you are plannin on runnin a stock 35 GTR and carryin a load on step is you main objective. I reccomend da length should be 18' - 19' and da width 50" - 56".
Fri Feb 05, 2010 11:53 am
Users browsing this forum: No registered users and 156 guests
