It is currently Fri Jun 27, 2025 4:35 am
[ 7 posts ] |
Swamp Star
Joined: Sun Jul 29, 2012 8:40 pm Posts: 246 Location: Central GA
 Gtr trim help
So the trim on my new motor has decided to start acting a fool at 34hrs. When triming either way it sounds and acts like its low on fluid. I pulled the trim off checked the fluid and went straight to the battery and it runs fine up or down. Well this made me think it was the switch so I just replaced the switch and it is still doing the same BS. I pulled the trim again and double checked the fluid and went back straight to the battery and its fine. I see that it is a Parker unit and I have a Parker store 40 miles from the house but I wanted to get yalls take and see if I may be missing something before I make the drive.
On a side note my motor is still under warrenty but I have to go threw my dealer 6.5hrs away since they bought the motor over a year ago. I bought the whole rig in July. And with our 2nd season opening up again next weekend I dont want my boat to be down.
_________________ Prodigy 2066 Center Console dual rig with GTR XD L3 Deltas
Sat Dec 05, 2015 11:29 am |
Hernaja1
Joined: Tue Feb 19, 2013 11:29 am Posts: 2465 Location: Sulphur , La
 Re: Gtr trim help
Have you tried bleeding it ? I now it takes a few times to bleed out all the air. Might have a air leak I'm guessing but I'm not sure.
_________________ Dual 37 EFI GTR's pushing a 20/72 , CC, point bow , Old school drake Camo Willet custom.
Sat Dec 05, 2015 3:23 pm |
Swamp Star
 Re: Gtr trim help
How do you bleed it? There is one allen bolt on the top and 2 plugs on the side. I was scared to pull the side plugs incase it had springs or anything that could come flying out at a high rate of speed. Haha.
Sat Dec 05, 2015 3:26 pm |
Hernaja1
 Re: Gtr trim help
Sorry I'm thinking of the throttle on a console unit. I think that trim unit is a sealed unit. Do you see it leaking at all ? Does it delay when you trim up or down before it decides to trim ? Only things I know that it could be is loosing fluid ( leak ) , or bad connection to the battery. I had both issues with my last trim unit.
Sat Dec 05, 2015 3:39 pm |
Swamp Star
 Re: Gtr trim help
I is like it stutters if that makes any scene. It trims very very slow either way. The trim is dry as a bone.
Sat Dec 05, 2015 7:27 pm |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
 Re: Gtr trim help
Could be bypassing with a load on it. Scratch on the ram from trash or a cut seal could do this. Call GT and talk with them they may send you a new one.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Sat Dec 05, 2015 8:15 pm |
duck_watcher12
 Re: Gtr trim help
I agree with buster, I'd call gator tail because it could be a seal or the pump might be weak
Sat Dec 05, 2015 11:32 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 193 guests |
