It is currently Wed Jun 25, 2025 10:25 am
[ 7 posts ] |
AK.airboater
 fuel line ?
installing a racor fuel water filter on a new boat build. racor suggest putting in a check valve at gas tank to prevent back flow and loosing prime. gas tank is less than 12 inches below filter and will be run to a new 23 hp mudbuddy with electric fuel pump. do any of you do this or think this is necessary ? seems like its not needed or one more thing to go wrong in system.
Mon Aug 29, 2016 11:43 am |
Will C
 Re: fuel line ?
Give it a go, u can always add a check valve later if u need one. Most on here don't have any sort of check valve
Tue Aug 30, 2016 8:09 am |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
 Re: fuel line ?
Correct me if I'm wrong, but most (if not all) primer bulbs have a built in check valve.
Even with an electric fuel pump, it’s a good idea to still run a primer bulb. What if the fuel pump fails? You can still manually send fuel to the motor. I believe it puts less strain on the e-pump, when you need to initially fill the line / filter.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
Tue Aug 30, 2016 8:28 am |
AK.airboater
 Re: fuel line ?
i was going to have a bulb in spare parts box and if needed splice it in line when needed. but now that you stated it has its own check valve which it does, maybe i should just put bulb in line now and be done with it ?
Mon Sep 05, 2016 1:16 pm |
brycecheramie
 Re: fuel line ?
Every time I have used a primer bulb on my mud boat, it has given me fits with air leaks or being a faulty bulb.
I don't run a primer bulb anymore and have never even needed it.
Mon Sep 05, 2016 5:04 pm |
AK.airboater
 Re: fuel line ?
That was my concern and reason for posting the question. Having a spare bulb in the boat box is easy enough to put in line if needed. It's one more thing to go wrong. Another question if you have a electric fuel pump in line and turn the key on and it bring power to pump will it not bring fuel to carb automatically like pumping a bulb on your outboard ?
Mon Sep 05, 2016 9:36 pm |
brycecheramie
 Re: fuel line ?
Mon Sep 05, 2016 10:25 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 302 guests |
