It is currently Fri Aug 01, 2025 9:31 pm
[ 6 posts ] |
duckbill
Joined: Tue Mar 31, 2009 9:40 am Posts: 238 Location: Dallas, Texas
 Location of primer bulb?
Where does everyone put their primer bulb? In between the motor and the water separator? In between the fuel tank and the separator? Just putting in a new fuel line and bulb and thought I'd ask. I tried to look through some of the pictures but couldn't find any that really showed where the bulb was.
Thanks, Duckbill
_________________ 1644 Go-Devil 2008 23 GDSD
Wed Apr 07, 2010 12:42 pm |
earl33
Joined: Wed Sep 16, 2009 3:47 pm Posts: 2261 Location: West Tennessee
 Re: Location of primer bulb?
between the fuel tank and the separator...... Or do away with it via a fuel pump...
_________________ If the Steel aint Flying the Birds aint Dying.... Uncle J 1948 holding a LT Uncle J 1848 w/?
Wed Apr 07, 2010 12:49 pm |
duckbill
I've got a fuel pump sitting around that I could use. I assume you would put it in the same place you would put the bulb. How do y'all wire 'em up? Put them on a switch and run it just when you need your motor primed, or wire it to your motor so that when the key is on the fuel pump is on? Thanks for the info.
Wed Apr 07, 2010 1:10 pm |
earl33
Here ya go..... search.php?fid[]=3 Type in fuel pump and get more info then at Auto Zone.... Some good reading and I think you will find whatca looking for....
Wed Apr 07, 2010 1:22 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
Learnin from my mistakes, as well as others' mistakes, I put mine on a toggle switch that only gets a power feed to it when the key is on. That way the only time the pump can be turned on is if the key is on. Only run the pump to prime the line, or if at WOT and fuel in filter starts to get low.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Wed Apr 07, 2010 8:19 pm |
jpc014
Joined: Tue Mar 10, 2009 8:17 pm Posts: 785 Location: Meraux, LA
i put my pump on my ignition the pump with not work without the key on i is easy to do. i also have my primer bulb inbetween the water separator and the engine. i have the flow restricted to about 2 lbs
HRCH Cajun Black "VOODOO" Magic 18x48 Center Console PD w/32PDHydro T&T; Hydro Reverse "If I wanted any of your lip; I would pull down my zipper"
Wed Apr 07, 2010 9:32 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 69 guests |
