It is currently Fri Jun 27, 2025 3:03 am
Stinkymud
Joined: Mon Dec 22, 2014 12:10 pm Posts: 146 Location: Becthelsville, Pa
 Re: Motor too high
I had the same issue as all the guys above in a tracker 1542 I cut the transom 2in now it's 15 and put a shim on the motor now I have a lot of adjustment down and up .. I have the bps exhaust and have had the carb messed with also adjusted the gov I run a steady 27mph at 4020rmps with 2 guys and gear just have to keep messing with it. The guys are right angle is huge on these small jons but If I did it again or on next rig for me I'd go with a mod v to stop plowing as much .. better water displacement also with these massed produced boats the are many things that make 1 different from the other .. mine has a slight hook in the back of boat which i can never get rid of that will also cause big issues in performance.
_________________ 23 COPPERHEAD PUSHING A MODIFIED TRACKER 1542
Sun Nov 15, 2015 12:01 pm |
Users browsing this forum: No registered users and 231 guests |
