Fuel/Water seperator?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=10062
Author:  Filter [ Sat Jun 05, 2010 1:02 pm ]
Post subject:  Fuel/Water seperator?
should i use teflon tape to seal the fittings on my new fuel water seperator?
thanks Lenny
Author:  cb5331 [ Sat Jun 05, 2010 1:04 pm ]
Post subject:  Re: Fuel/Water seperator?
I did
Author:  TURBODRIVE [ Sat Jun 05, 2010 1:05 pm ]
i did
Author:  Filter [ Sat Jun 05, 2010 1:27 pm ]
cool just wanted to make sure, the instructions said nothing about it
Thanks
Author:  Capt Jeff Kraynik [ Sun Jun 06, 2010 7:55 am ]
Often used but not recommended.
As the standard teflon tape degrades or pieces break off during installation. The fuel grade tape doesn't degrade but also breaks off & run through the fuel system & clog the needles on the carb.
Couple years back I had a engine surge problem on my GD & had the mechanic broke open the carb.
There was a piece of fuel grade teflon tabe about the size of a well sharpened pencil in the carb.
I went home & changed out all the boats.
The tape also rapidly breaks down with ethanal fuel.
There are anti-seize products that work just as well or better w/o effecting the carb or fuel system.
The best I found was @ a local speed shop.
Author:  JIMMY W [ Sun Jun 06, 2010 10:34 am ]
Author:  Filter [ Sun Jun 06, 2010 5:36 pm ]
thanks CJ
Author:  Capt Jeff Kraynik [ Mon Jun 07, 2010 7:50 am ]
Author:  JIMMY W [ Mon Jun 07, 2010 9:09 am ]
Author:  MaXXis85 [ Mon Jun 07, 2010 1:16 pm ]
Most fuel fittings are PIPE thread. Which means they are tapered and seal by interference fit. No teflon needed!
