It is currently Sat Aug 02, 2025 1:33 pm
Reply to topic  [ 10 posts ]
 Fuel/Water seperator?
Post Fuel/Water seperator?
should i use teflon tape to seal the fittings on my new fuel water seperator?
thanks Lenny
Black Dogs are the Best Dogs
16ft Alumacraft Waterfowler with a 2013 Mud Buddy 35CDI HD
Sat Jun 05, 2010 1:02 pm
Post Re: Fuel/Water seperator?
I did
Sat Jun 05, 2010 1:04 pm
i did
Sat Jun 05, 2010 1:05 pm
cool just wanted to make sure, the instructions said nothing about it
Thanks
Sat Jun 05, 2010 1:27 pm
Often used but not recommended.
As the standard teflon tape degrades or pieces break off during installation. The fuel grade tape doesn't degrade but also breaks off & run through the fuel system & clog the needles on the carb.
Couple years back I had a engine surge problem on my GD & had the mechanic broke open the carb.
There was a piece of fuel grade teflon tabe about the size of a well sharpened pencil in the carb.
I went home & changed out all the boats.
The tape also rapidly breaks down with ethanal fuel.
There are anti-seize products that work just as well or better w/o effecting the carb or fuel system.
The best I found was @ a local speed shop.
If your courage holds, luck will get you through most situations!!!
Sun Jun 06, 2010 7:55 am
Sun Jun 06, 2010 10:34 am
thanks CJ
Sun Jun 06, 2010 5:36 pm
Mon Jun 07, 2010 7:50 am
Mon Jun 07, 2010 9:09 am
Most fuel fittings are PIPE thread. Which means they are tapered and seal by interference fit. No teflon needed!
Mon Jun 07, 2010 1:16 pm
Users browsing this forum: No registered users and 177 guests
