It is currently Fri Aug 01, 2025 5:14 am
Reply to topic  [ 10 posts ]
 23hp sd vs. 27hp sd
Post 23hp sd vs. 27hp sd
Wondering if anyone had a 23hp GoDevil sd, and if so what is your take on it? Reason being, im getting a 16x48 sd boat built and using my longtail for the time being, just need some insight and what to look for. Thanks
Wed Mar 24, 2010 11:58 am
Post Re: 23hp sd vs. 27hp sd
The 23 meets the under 25 hp rule for Federal Properties....
Other than that the 25 or 27 Kohler is a better motor in terms
of torque and powerband... The 23 is a bit weaker on the
bottom end of the rpm band than the Kohler - I think the
25 and 27 are about the same except for the carb....
In the GDSD the 23 has a shorter outdrive than the 27 with
a lower gear ratio to make up for the lack of torque - so that
they both can use the 3 blade - 1.4 to 1 on the 35 - 1.5 to 1
on the 27 - 1.7 to 1 on the 23 GDSDs.....
On the right hull the 23 GDSD is a great motor - Sam III here has
the 23 GDSD & 18x36 GD Skiff and can outperform many larger hulls
in the slop with the bigger 35 GDSD - no chit - seen it happen just
2 weeks ago at "our run" -LOL- !!!
I have a GDSD 16x48 myself and have run the 23LT - 27 GDSD - and
now the 35 GDSD.... The 23LT would get me thru the toughest
places --- but I like the 35 GDSD the best --- 30 plus mph and easy
to drive....
Eat - Sleep - Hunt ! ! !
Wed Mar 24, 2010 12:06 pm
Dude get the 27HP…I have a 16X60 GD and The 27HP SD and it’s a TURD with 3 people…wish I had a bigger motor…Bigger is always better….
16X60GD 27HP Surface Drive
Wed Mar 24, 2010 5:39 pm
Profile YIM WWW
Hey, thanks for the info guys. Ill be looking more in to it in another couple months. Maybe once i get it all setup, i can hit them muddi gras. Booyah-k-Sha..
17.6 x 48" Uncle J w/ GTR35
Thu Mar 25, 2010 8:53 am
Giga-I have a 2003 16X44 GD Duck Boat.I started out with a 23 LT.
I updated to a 23 GDSD because I didn't think the boat could handle the 35GDSD. Do you think otherwise??
Thu Mar 25, 2010 12:07 pm
Hey Dano, I'm runnin a 35 MB on a 16/44 GD. Does great, wouldn't change a thing. ;)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Mar 25, 2010 1:25 pm
Thu Mar 25, 2010 3:45 pm
get the biggest ya can.
ETD88 09/28/09-05/14/2010...
Fri Mar 26, 2010 10:10 am
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Mar 26, 2010 5:51 pm
put you a 35gtr on that bad boy
18x54 xtreme huntdeck 35gtr
camo designs custom paint
Sat Jun 26, 2010 9:53 pm
Users browsing this forum: No registered users and 81 guests
