It is currently Tue Jul 29, 2025 8:20 pm
Reply to topic  [ 9 posts ]
 need a bit of advise
Post need a bit of advise
i got a 1648 alum boat with a 21" transom and 18 inch side's, 68" at the top. i been lookn at longtails for a while. and me, i like power. so i been lookn at mudbuddy 35 vanguard longtail. i like the mudbuddy 35 longtail cause of the weight and the cost. so would i be able to run it on this here 21" transom.
or do i need to do sum cutn n weldn on the thing.
i am a welder so i will probably weld up all the rivets on it.
Sun Jun 20, 2010 12:04 pm
Post Re: need a bit of advise
I know GD has a model for a 20" transom, I don't know what MB offers but would assume they offer one for a tall transom.
Sun Jun 20, 2010 12:15 pm
You defently got the right idea of having as much power as you can. Though, the welding the rivet comment bothers me. In the past, I have welded rivets for people, and it is a pain in the azz. I think these boats are painted before assembled. Seems you can not clean it good enough. Then before you know it, you end up blowing through the alum. Though, I wish you the Best of Luck.
Uncle J
Sun Jun 20, 2010 12:33 pm
Jay Dore
Sun Jun 20, 2010 12:43 pm
i know some that use contact cement and weatherstrip sealent on rivets.... i know they use it on airboats a good bit when poly rivets leak...
Sun Jun 20, 2010 12:47 pm
Sun Jun 20, 2010 1:35 pm
Having tried to do exactly what you are trying I would advise you to sell the boat and find a used mud boat. You will be very pleased with the results. ;)
My Chessie is the Queen of the Marsh!!!!
"The democracy will cease to exist when you take away from those who were willing to work
and give to those who would not." Thomas Jefferson-1802
"When the Government fears the people that is liberty
When the people fear the government that is tyranny"- Thomas Jefferson
Sun Jun 20, 2010 1:47 pm
Sun Jun 20, 2010 2:08 pm
if i had 2 weld them i would use pulse mig."tig is gona build up 2 much heat before it puddles on dirty rivits"I would weld a loop around the rivit bout the size of a nickel and then spiral in to the middle. have done thousands of times but only in a half 2 situation. also when welding the rivits watch for rib seperation. when those rivits ghet hot they will pull through if there is tension on them. i suggest tacking the ribs down before starting a major rivit welding job.
Jay Dore
Sun Jun 20, 2010 5:30 pm
Users browsing this forum: No registered users and 137 guests
