Need info on a 25 prodrive performance
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=10970
Author:  duckhead75 [ Sat Jul 17, 2010 7:17 pm ]
Post subject:  Need info on a 25 prodrive performance
I hunt an area that has a 25hp limit so I have been wondering about a 25pd on a 1748 pd boat? Would that carry 3ppl and gear(600lbs in meat and 150lb in b.s.) at a decent speed and get on plane at a relatively decent pace? I know there are some upgrades on these motors but the more I read about those the motors turn into bombs basically, so would a simple upgrade help this kind of situation?
Author:  cb5331 [ Sat Jul 17, 2010 7:55 pm ]
Post subject:  Re: Need info on a 25 prodrive performance
There's plenty of mods for the kohlers. Do a google search for cub cadet tractor pulling. They don't build huge hp with simpler mods like the briggs motors, but they hold up well. And pretty much all the same stuff is available as what is out there on the briggs. On the 25 some simple mods, are just to put the parts from the 30 on them. Example: heads, carb, intake, etc. The 25 supposedly produce more power than the 30 when adding those parts. Think it has something to do with the cam. Anyway, there's lot of stuff out there. And lots of stuff that your motor actually comes assembled with, so you don't have to worry bout building a grenade.
Author:  stumpgrinder [ Sun Jul 18, 2010 10:31 am ]
Author:  duckhead75 [ Sun Jul 18, 2010 9:10 pm ]
Thanx CB
Stump, I will be in some GTr's and running a few rivers looking in some shallow hardwood flooded bottoms. I am worried about keeping an outboard cleave and trash free hence the mudmotor. I don't know how well an 1848 would get around in the woods. ...
Author:  stumpgrinder [ Mon Jul 19, 2010 7:16 am ]
If da woods aren't thick enough to be concerned with a 4' bottom then you won't have trouble with an 18' boat vs. 17'. I spend more time in thick woods during 1 crawfish season than most hunters do in a lifetime and I wouldn't have nuthin less than a 20' skiff.
Good luck!
Author:  duckhead75 [ Sun Jun 05, 2011 8:59 pm ]
Anyone got any advise on the proper boat for a 25hp prodrive that will carry a load of 3ppl and some hunting crap??
Author:  POKER1 [ Sun Jun 05, 2011 9:03 pm ]
I wouldn't go less than an 18x48. Can you even get a new 25 PD? Maybe a used one if you can find one.
Author:  med [ Mon Jun 06, 2011 12:48 am ]
Id listen to what s.grinder has to say....stump how many hrs do you put on a rig per yr do ya think?
Sent from my iPhone 5
Author:  XGEN-DUCKMAN [ Mon Jun 06, 2011 4:21 am ]
X2 on what Stumpy said, he puts more hrs in afew yrs then some guys will in a lifetime......18ft or nothing......... Kohler has aton of stuff, checkout http://www.midwestsupercub.net/... from 30hp heads to carbs and cams, your 25hp could be pushing 35plus very easily with just a few easy mods.................my .02
Author:  pooldoo73 [ Mon Jun 06, 2011 2:28 pm ]
If your restricted to 25 and mod the motor in any way that is noticeable, you will still get fined if checked.
Author:  XGEN-DUCKMAN [ Mon Jun 06, 2011 7:33 pm ]
Author:  pooldoo73 [ Mon Jun 06, 2011 8:04 pm ]
25 is 25. Heads and the carb off a 30 won't b noticed. If u add an aftermarket exhaust u will get a fine at some point, because everyone can tell it ain't original. Play it right and u will b ok.
Author:  med [ Mon Jun 06, 2011 8:28 pm ]
One thing is for sure....if a gw wants to give you a ticket, you will get a ticket.
Author:  med [ Mon Jun 06, 2011 8:30 pm ]
Clay whats the best kohler site to order from? I know you were not satisfied with one of em but I cant remember which place it was.
Author:  cb5331 [ Mon Jun 06, 2011 8:32 pm ]
Skip seems to have gotten his shit together but I'd still have a hard time dealin with them again. He had a lot of family stuff goin on when I was putting my motor together, but still..
Midwest super cub is who I would order stuff like heads from or the 30 carb if you chose to go that route. I would stick with evt if you get to lookin' for a cam. The one's the tractor guys use are a lil too agressive for your needs
