It is currently Tue Jul 29, 2025 8:29 pm
Reply to topic  [ 3 posts ]
 Prodrive power trim failure
Post Prodrive power trim failure
Power trim will not move in either up or down position. Is there a fuse? There doesn't appear to be any power getting to the pump. Any hints other than call PD? I only have 10 hrs on it, but it's 14 months old so not sure if they will warrentee any failed object.
Sun Aug 15, 2010 6:49 pm
Post Re: Prodrive power trim failure
Take the cover off the trim switch and check to see if you have some loose wires. It is possible that the wires were pulled slightly and the connectors came loose. Mine did this 4th of July weekend. Mine has the blade type connectors so the fix was super easy.
Sun Aug 15, 2010 7:06 pm
Found it. The quick-connects down by the unit came off the wires. Looks like some one at PD needs to "muscle-up" a little. The sleaves were barely squeezed. I think I'll solder them together.
Mon Aug 16, 2010 7:20 am
Users browsing this forum: No registered users and 86 guests
