cmiller73
Joined: Tue Jan 12, 2010 12:42 pm Posts: 2161 Location: Houma,LA
 Rust-Oleum Truck Bed Coating
I bought some Rust-Oleum Truck Bed Coating from lowes and was planning to coat the bottom of my boat. Not from the inside but the underside. Just incase there are pinholes the posibility of a leaking rivet (haven't had one leaking yet). Should I do this? Will it do any good?
I plan to use a short nap roller that way it doesn't texture too much. 1 thin coat is all I want to put on.
Thanks
_________________ Copperhead 12Hp SD on 1442 Alweld
Tue Aug 10, 2010 8:54 am |
jus10inla
Joined: Tue Jan 13, 2009 5:55 pm Posts: 1636 Location: Baton Rouge, LA (Central)
 Re: Rust-Oleum Truck Bed Coating
Bring it back. Go to auto zone and they have it in the spray can. Thats how i did my rhino bed n 4 whlr rack
Tue Aug 10, 2010 9:54 am |
caddobrook
I would not put that on the bottom of your boat... especially for that reason.... It is too rough... and will create a lot of drag on the bottom of your boat...
I would go with coat-it or something else like that (steelflex or frogspit)
just my .02
Tue Aug 10, 2010 10:59 am |
cmiller73
Thanks guys. I was wondering if it would be too rough or rubbery. I'll be looking at the other products.
Tue Aug 10, 2010 12:48 pm |
ucsdryder
I sprayed the floor of my boat with that stuff and so far so good. It isn't nearly as rough as spray in bedliner more like sand paper. The bottom of the boat was done with steel flex which is absolutely awesome.
Thu Aug 12, 2010 8:35 pm |
cmiller73
What is the best place to get steelflex or frogspit?
Fri Aug 13, 2010 7:09 am |
cb5331
Use the search feature. Steelflex you get from fasco epoxies, which has been posted more than once. Frogspit can be had from I think its floral city airboats. Either way, both are on this site already numerous times...
Fri Aug 13, 2010 7:27 am |
Mudgun
Joined: Wed Jan 14, 2009 12:24 pm Posts: 746 Location: Here Be Rocks VA
Just to let you know, a slightly rough texture like rhino will actually be a faster bottom than a smooth slick surface.
May not be ideal for sliding over stuff, but it won't create drag.
_________________ 1660 Rhino High-Side with center console 90/65 Mercury 2 stroke Outboard jet pump Run shallow, run loud.
Sat Aug 14, 2010 6:33 pm |
cmiller73
Mon Aug 16, 2010 7:15 am |
oncall
Joined: Mon May 10, 2010 1:46 pm Posts: 1180 Location: Georgia
like fish scales
_________________ 1854 Brother pulling a 36 PD viewtopic.php?f=5&t=12825 Brooks: "Tries masterbation and thank happy thots ...... purt near pulled mines off when I quit 'em ....."
Mon Aug 16, 2010 11:06 am |
