Rust-Oleum Truck Bed Coating https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=11532 |
Author: | cmiller73 [ Tue Aug 10, 2010 8:54 am ] |
Post subject: | Rust-Oleum Truck Bed Coating |
I bought some Rust-Oleum Truck Bed Coating from lowes and was planning to coat the bottom of my boat. Not from the inside but the underside. Just incase there are pinholes the posibility of a leaking rivet (haven't had one leaking yet). Should I do this? Will it do any good? I plan to use a short nap roller that way it doesn't texture too much. 1 thin coat is all I want to put on. Thanks |
Author: | jus10inla [ Tue Aug 10, 2010 9:54 am ] |
Post subject: | Re: Rust-Oleum Truck Bed Coating |
Bring it back. Go to auto zone and they have it in the spray can. Thats how i did my rhino bed n 4 whlr rack |
Author: | caddobrook [ Tue Aug 10, 2010 10:59 am ] |
I would not put that on the bottom of your boat... especially for that reason.... It is too rough... and will create a lot of drag on the bottom of your boat... I would go with coat-it or something else like that (steelflex or frogspit) just my .02 |
Author: | cmiller73 [ Tue Aug 10, 2010 12:48 pm ] |
Thanks guys. I was wondering if it would be too rough or rubbery. I'll be looking at the other products. |
Author: | ucsdryder [ Thu Aug 12, 2010 8:35 pm ] |
I sprayed the floor of my boat with that stuff and so far so good. It isn't nearly as rough as spray in bedliner more like sand paper. The bottom of the boat was done with steel flex which is absolutely awesome. |
Author: | cmiller73 [ Fri Aug 13, 2010 7:09 am ] |
What is the best place to get steelflex or frogspit? |
Author: | cb5331 [ Fri Aug 13, 2010 7:27 am ] |
Use the search feature. Steelflex you get from fasco epoxies, which has been posted more than once. Frogspit can be had from I think its floral city airboats. Either way, both are on this site already numerous times... |
Author: | Mudgun [ Sat Aug 14, 2010 6:33 pm ] |
Just to let you know, a slightly rough texture like rhino will actually be a faster bottom than a smooth slick surface. May not be ideal for sliding over stuff, but it won't create drag. |
Author: | cmiller73 [ Mon Aug 16, 2010 7:15 am ] |
Author: | oncall [ Mon Aug 16, 2010 11:06 am ] |
like fish scales ![]() |
