Prodrive power trim failure https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=11661 |
Author: | Ducknut [ Sun Aug 15, 2010 6:49 pm ] |
Post subject: | Prodrive power trim failure |
Power trim will not move in either up or down position. Is there a fuse? There doesn't appear to be any power getting to the pump. Any hints other than call PD? I only have 10 hrs on it, but it's 14 months old so not sure if they will warrentee any failed object. |
Author: | Phathead [ Sun Aug 15, 2010 7:06 pm ] |
Post subject: | Re: Prodrive power trim failure |
Take the cover off the trim switch and check to see if you have some loose wires. It is possible that the wires were pulled slightly and the connectors came loose. Mine did this 4th of July weekend. Mine has the blade type connectors so the fix was super easy. |
Author: | Ducknut [ Mon Aug 16, 2010 7:20 am ] |
Found it. The quick-connects down by the unit came off the wires. Looks like some one at PD needs to "muscle-up" a little. The sleaves were barely squeezed. I think I'll solder them together. |
