It is currently Thu Jul 31, 2025 8:33 am
Reply to topic  [ 10 posts ]
 Rust-Oleum Truck Bed Coating
Post Rust-Oleum Truck Bed Coating
I bought some Rust-Oleum Truck Bed Coating from lowes and was planning to coat the bottom of my boat. Not from the inside but the underside. Just incase there are pinholes the posibility of a leaking rivet (haven't had one leaking yet).
Should I do this? Will it do any good?
I plan to use a short nap roller that way it doesn't texture too much. 1 thin coat is all I want to put on.
Thanks
Copperhead 12Hp SD on 1442 Alweld
Tue Aug 10, 2010 8:54 am
Post Re: Rust-Oleum Truck Bed Coating
Bring it back. Go to auto zone and they have it in the spray can. Thats how i did my rhino bed n 4 whlr rack
Tue Aug 10, 2010 9:54 am
Profile YIM WWW
I would not put that on the bottom of your boat... especially for that reason.... It is too rough... and will create a lot of drag on the bottom of your boat...
I would go with coat-it or something else like that (steelflex or frogspit)
just my .02
Tue Aug 10, 2010 10:59 am
Thanks guys. I was wondering if it would be too rough or rubbery. I'll be looking at the other products.
Tue Aug 10, 2010 12:48 pm
I sprayed the floor of my boat with that stuff and so far so good. It isn't nearly as rough as spray in bedliner more like sand paper. The bottom of the boat was done with steel flex which is absolutely awesome.
Thu Aug 12, 2010 8:35 pm
What is the best place to get steelflex or frogspit?
Fri Aug 13, 2010 7:09 am
Use the search feature. Steelflex you get from fasco epoxies, which has been posted more than once. Frogspit can be had from I think its floral city airboats. Either way, both are on this site already numerous times...
Fri Aug 13, 2010 7:27 am
Just to let you know, a slightly rough texture like rhino will actually be a faster bottom than a smooth slick surface.
May not be ideal for sliding over stuff, but it won't create drag.
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Sat Aug 14, 2010 6:33 pm
Mon Aug 16, 2010 7:15 am
like fish scales :D
1854 Brother pulling a 36 PD
viewtopic.php?f=5&t=12825
Brooks: "Tries masterbation and thank happy thots ...... purt near pulled mines off when I quit 'em ....."
Mon Aug 16, 2010 11:06 am
Users browsing this forum: No registered users and 125 guests
