PD Winch Trim https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=11870 |
Author: | Full Throttle [ Mon Aug 23, 2010 2:11 pm ] |
Post subject: | PD Winch Trim |
Well, I've burnt up my 3rd super winch 2000 in about 125 hours..... I don't have a problem using the winch trim, but it just isn't reliable. Should I try another brand winch? If so, which one? Or should I pony up and get the hydrolic replacement? Thanks. |
Author: | cb5331 [ Mon Aug 23, 2010 2:26 pm ] |
Post subject: | Re: PD Winch Trim |
You could always go to a better winch. You know the warn's are a quality product but the prices are pretty steep, and may put you in the ballpark of a hydro set up. Some of the guys on here have been having good luck with the gorilla winch products on ebay. They recently changed the name of the company but still the same product. Prices are more similar to the superwinch. I have 2 of the superwinches and haven't had any problems yet. One on the front of the boat, and one for the trim. |
Author: | OwenDickeson [ Mon Aug 23, 2010 3:51 pm ] |
You need to find one with a strong brake that can hold the weight of the motor. Thats what failed on all of mine. 3 or 4 of em. |
Author: | mudman350 [ Mon Aug 23, 2010 4:29 pm ] |
the power trim is great. id spend the 500 and get it. i love it |
Author: | Brinkleydog [ Wed Aug 25, 2010 1:15 pm ] |
run one of each righ tnow and i kinda like the winch trim better than the hydro.....after busting 2 pumps it seams the winch would be easer to fix when it does break. Before you change search how many peopel have had problems out of the hydro...line busting, no power, cracket pumps, pusted parts..... If you loose a winch you can still get back to the ramp by just taking up the slack....bust a hydro and you need some redneckn to get back. I keep 18" of cable with a loop on both ends in my boat just incase i bust a line or crack another bar. |
Author: | Full Throttle [ Wed Aug 25, 2010 1:20 pm ] |
Kind of what I was thinking, James..... I ended up just getting another superwinch2000. As it turns out, I had bought a $6.99 warranty for it at Northern Tool and they gave me a brand new one for free. |
Author: | Brinkleydog [ Wed Aug 25, 2010 1:38 pm ] |
Good deal..... Get your boat loaded up and lets ride man...if you bowfish be probably be going this weekend give me a ring. |
Author: | Shadow [ Wed Aug 25, 2010 6:13 pm ] |
Author: | bombdude [ Wed Aug 25, 2010 6:50 pm ] |
Glad it worked out for you. For the record, I'm still using my original winch trim, & it hasn't let me down yet. Now watch it fail this weekend now that I've bragged on it. |
Author: | Full Throttle [ Wed Aug 25, 2010 7:07 pm ] |
Author: | Shadow [ Wed Aug 25, 2010 8:34 pm ] |
I'd like to see a picture of the winch trim up close. Never seen one. |
Author: | cb5331 [ Wed Aug 25, 2010 8:56 pm ] |
Author: | Full Throttle [ Thu Aug 26, 2010 6:20 am ] |
I put that same blue rope on mine as well. Got it off ebay. Had it break once, so I'm gonna stick with the new cable for a little while and see how it does. |
Author: | Shadow [ Thu Aug 26, 2010 11:07 am ] |
Could you not make an electric actuator work for a trim? Mounting plate would be the hardest thing...one from hydralic trim may work... never seen one of those up close either. To use the winch trim do you just mainly need a special bracket? Sorry for the questions....dont really have time to search right now and I've never seen them in person. Just know what I got. Here is an idea I had a while back.... its off the wall but The manual trim uses a screw( i call it) for its trim. What if you used something like this..... Im not sure how fast it is but... |
Author: | Brinkleydog [ Thu Aug 26, 2010 11:23 am ] |
not able to see the image but if you r talking about a servo motor they would work just have to find one that will hold up. |
Author: | cb5331 [ Thu Aug 26, 2010 11:38 am ] |
Author: | Shadow [ Thu Aug 26, 2010 11:53 am ] |
Brinkley - Its just a 12V car jack. It has the long screw like on the manual trim. CB - I'll just keep turnin the handle for now. I just dont know how I like the looks of the hydraulic trim.. |
Author: | OwenDickeson [ Thu Aug 26, 2010 12:03 pm ] |
Author: | cb5331 [ Thu Aug 26, 2010 12:05 pm ] |
On that jack, the motor must spin a gear that turns the screw. If you removed the wheel off the bolt on the pd, and took the motor off the jack, maybe you could get the gear to spin the bolt. I see what you're trying to do. Looks like a lot of headache to me... How much are those little jacks? Or can you buy the motor separately? |
Author: | OwenDickeson [ Thu Aug 26, 2010 12:10 pm ] |
Quick question that is sort of relevant. Does anyone know if you were to call PD and order a hydro trim to replace your manual, would that new trim unit come with a 1 year warrenty? |
Author: | cb5331 [ Thu Aug 26, 2010 12:19 pm ] |
Owen, I think it would. I know they gave us a warranty on the new lower unit... |
Author: | Brinkleydog [ Thu Aug 26, 2010 12:44 pm ] |
my first busted hydro pump was not quite 2 yrs old and they sent me a replacement which was used. They had to do this becasue they no longer used the style pump. when that one busted i had to purchas the new pump for 275??? i think. I'm sure if it goes out they will send a new one but the way my luck is i would have to pony up and purchas one. |
Author: | Shadow [ Thu Aug 26, 2010 1:30 pm ] |
Author: | BAG Hunter [ Thu Aug 26, 2010 8:31 pm ] |
Author: | Brinkleydog [ Fri Aug 27, 2010 6:39 am ] |
up n DeKalb at my lease. be careful on the river bro its choked full of crap......i only go to he river when the wife and kids stay at home and thats not often. |
Author: | TURBODRIVE [ Fri Aug 27, 2010 8:57 am ] |
ive had my winch trim since 06, its whatever brand that PD put on their, but its held up great |
