mississippiduckboy
 Antique Go Devil
So i baught this little 8hp go devil from a man over in louisiana for 300 thinking im going to have alot of work and all, well sure enough i got it home placed it on the boat and she fired right up i got to looking at it and sure enough its got the very first design that go devil did for its props and its made of brass i think you can see how little they have changed it the past at least 15 years. This motor on it is so old that its back when brigs and stratton still had the circle airfliter with the metal thing over it. Im going to get the numbers off the motor and call go devil to see just how old this bad boy is.
_________________ 14 by 44 Weld Craft powered by a 20hp. go devil longtail Team Arc Angel Bowfishing
Sat Sep 04, 2010 1:45 am |
quack addict
Joined: Tue Jan 13, 2009 5:44 pm Posts: 620 Location: Metairie, LA
 Re: Antique Go Devil
maybe you can get the antique license plate for your trailer, lol
_________________ "I have been blessed with many things in this life, an arm like a rocket, a c*ck like a Burmese Python and a mind of a f*ckin scientist." -Kenny F*ckin Powers
Gator Trax 3-Man Gatorhide with a Mud Buddy HD Sport 5000
Large Big Green Egg with rounded chines
Sat Sep 04, 2010 9:19 pm |
Josh
Joined: Fri May 14, 2010 7:35 am Posts: 1110 Location: Longview TX
buddy of mine has a frame with the brass prop
_________________ Sometimes it's best to just keep your fingers quiet...
Sat Sep 04, 2010 10:51 pm |
backwaterballer
Joined: Sat Feb 21, 2009 9:39 pm Posts: 715 Location: Pearland Tx
I have one in my shop right now the motor is actually welded to the shaft.
_________________ 23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl 35 hp gdsd pushin a 16/60 go devil boat
Sat Sep 04, 2010 11:51 pm |
JD
You should not talk about Warren Cocco that way!
JD
Sun Sep 05, 2010 7:47 am |
mississippiduckboy
I think this one is welded on to because this is going to be the death of me trying to get this thing off the shaft
Mon Sep 06, 2010 8:08 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
I was just looking at a small bronze prop that came off an old 5hp we had,its still down in a trapping shed we have. That motor is a little over 20 years old now. Katrina killed the engine but there is nothing wrong with it.
Tue Sep 07, 2010 3:52 am |
mississippiduckboy
Them bronze props hold up some much longer to like this motor has been running and being used for the last 15 to 20 years as well i would think once i get it off and put a new prop and shaft on that this motor will run so much better seeing how thin these props were back then.
Tue Sep 07, 2010 9:25 pm |
kibb
The brass props are keyed and come straight off.
Wed Sep 08, 2010 5:49 pm |
mississippiduckboy
like i cant get the nut off the shaft to get the prop off it like the nut is locked on and i cant get it off
Wed Sep 08, 2010 8:35 pm |
