All Right Boys - Pic the Right Motor for this rig https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=12769 |
Author: | Rem [ Fri Oct 01, 2010 7:42 am ] |
Post subject: | All Right Boys - Pic the Right Motor for this rig |
Here's your boat: Lowe Roughneck '03. 1760MT (mod v w/ tall, 20" transom). hull weight I believe is around 500 lbs. (two pod style vs. full, rear bench) 2-3 guys, 90 decoys, boat blind and a dog. surprising to me, it's only rated for a 40 on the USGS cert. what are you throwing on the back of it. (I'm not completely positive a 35 is enough) thoughts? |
Author: | latravcha [ Fri Oct 01, 2010 8:11 am ] |
Post subject: | Re: All Right Boys - Pic the Right Motor for this rig |
40 merc |
Author: | cmelvin [ Fri Oct 01, 2010 10:22 am ] |
40 yamaha ![]() |
Author: | mississippiduckboy [ Fri Oct 01, 2010 10:24 am ] |
are you running mud or deep water or what |
Author: | quackconsumer [ Fri Oct 01, 2010 10:31 am ] |
90 mercury |
Author: | fowl habbit [ Fri Oct 01, 2010 12:02 pm ] |
Put a 85 yamaha 4 stroke tiller on her/ Haulin names and takin A## |
Author: | Noladucks1 [ Fri Oct 01, 2010 12:54 pm ] |
If somebody in LA had built a 60" wide 17 fter, it would be rated for a 115. |
Author: | kibb [ Fri Oct 01, 2010 1:53 pm ] |
90 Yama 2 stroke wit a tiller. |
Author: | JIMMY W [ Fri Oct 01, 2010 5:34 pm ] |
Deep Water - Mercury 115 Optimax with tiller!!Make sure to turn your hat around ![]() Mud - Gator-Tail 35!!Still might want to turn your hat around ![]() |
Author: | T-Bubba [ Fri Oct 01, 2010 6:09 pm ] |
100lb trust minnkota.. ![]() why post this dumbass thread and not say what terrain your runnin..... could be a 2 acre pond or a 50 ft lake or some 1ft flats. |
Author: | radikkle [ Fri Oct 01, 2010 6:32 pm ] |
dmd's scavenger... ![]() |
Author: | cb5331 [ Fri Oct 01, 2010 6:38 pm ] |
x2 |
Author: | Woodiebuster [ Fri Oct 01, 2010 6:45 pm ] |
Author: | DeathMetalDukk [ Sat Oct 02, 2010 9:49 am ] |
Author: | DeathMetalDukk [ Sat Oct 02, 2010 9:50 am ] |
Author: | b_coonass [ Sat Oct 02, 2010 8:52 pm ] |
V8 Vortech! ![]() |
Author: | Josh [ Sat Oct 02, 2010 10:46 pm ] |
All Right Boys- Pick the Right Forum for this Thread.... |
Author: | Tenpoint [ Sun Oct 03, 2010 7:44 am ] |
225 Pro Max |
Author: | b_coonass [ Sun Oct 03, 2010 10:29 am ] |
Author: | chocolate head [ Sun Oct 03, 2010 7:29 pm ] |
GTR 35 is all you need. |
Author: | Rem [ Mon Oct 04, 2010 7:09 am ] |
Thanks for the comments so far and you're right; I should've given a bit more info as to type of water I'm running. sorry about that. we'll be hunting a clean,clear(er) shallow water basin with water depths averaging 12-18" and maybe 2ft at the deepest. there's a number of deeper water cuts used to motor out and into the area, but the real gem would be to be able to cut across the basin vs. doing a big end around. Part of me really wants to try a surface drive on this becuase; 1. never had one and it looks awesome. 2. it'd certainly work 3. I already own an alaskan 18' with a big A$$ outboard 4. this is where i hunt....now. thats not to say I wouldn't want to trailer it up and throw it into a weed choked river/bayou sometime (particularly, when I have the other rig). having said that, my struggle is still do I just jack a Yami ? or go with a surface drive? (and by the comments, I see that maybe outboard is still the way to go - probably not the best mud hull?) and the reason I put it here is that I figured it was more of a boat AND motor discussion where it's not a review , but a "critics choice" commentary of "if you had this hull, match up a motor". and for the record.... I did post it in the other forum as well. was just looking for more opinions. |
