shooter
 Converting PD Twist Throttle to Squeeze?
Not real happy with the twist throttle design, I make some pretty long runs and the trial run yesterday was a fair amount of work. Now the twist grip was sliding some on the shaft, I think I got that fixed. Also added some shims to hopefully cinch things up just a little so that it wasn't quite so touchy.
I did some research last night and didn't really find what I was looking for. Anyone figgered out a good way to change this control?
_________________ 32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Fri Oct 01, 2010 11:00 am |
bfenn
Joined: Fri Apr 10, 2009 8:05 pm Posts: 258 Location: Port Neches, Tx
 Re: Converting PD Twist Throttle to Squeeze?
I changed out mine, I ordered the BPS stainless throttle lever from mud buddy. I took all the guts out of my pd handle (rod and rubber bushings) then I had a 20" peice of aluminum round stock machined 12" at 3/4, then 1 1/2" at 1 1/8 (i think), and then 6 1/2" at 7/8. The 3/4 part slides into the tube, the 1 1/8 fits into where the rubber bushing was, and the 7/8 sticks out for your throttle and hand grip. I put locktite on it when I put it in to hold it in and still be removeable, I also thought about drilling through the 1 1/8 part and putting a 1/4 bolt or welding it in. Before you have one made double check these measurements.
_________________ 1754 Gatortail with 35 GTR 1748 prodrive pushed by a genny (SOLD)
I shoot black mallards does that make me guilty of a hate crime?
Fri Oct 01, 2010 2:18 pm |
BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
You have any pics?
Fri Oct 01, 2010 9:29 pm |
bfenn
no pics before I installed it ---sorry
Sat Oct 02, 2010 7:03 am |
OwenDickeson
I think he wants to see it installed
Sat Oct 02, 2010 10:06 am |
Sando
Joined: Wed Jul 07, 2010 6:41 am Posts: 399 Location: Texarkana, AR
I wouldn't mind seeing it installed myself, do you like it being a squeeze grip more than a twist?
_________________ FEAR MY WAKE!!!! http://mudmotortalk.com/mmt_v2/viewtopi ... =5&t=12134
Sat Oct 02, 2010 11:35 am |
Team Camo
Sat Oct 02, 2010 2:55 pm |
BradS
I happen to have a PD sitting in the driveway -- I can see all the pre-installed I want -- I wanna see POST INSTALL
Thanks -- and I hope you were drunk when you posted that --- other wise Im begining to see a pattern in SETX
Sat Oct 02, 2010 9:01 pm |
Team Camo
 pha que Brad.
Sat Oct 02, 2010 11:00 pm |
shooter
Ran again today after adding shims to the tolerance stack and cinching down some. Glued the twist grip to the throttle rod. Much better now. Gonna keep it this way for a while.
Sun Oct 03, 2010 3:15 am |
BradS
Sun Oct 03, 2010 6:50 am |
