autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 CNC milled billet parts available soon
Hey guys, I just set up my shop with a CNC milling machine. I will be able to cut any 3D part that can fit into a 20" long by 5" deep by 10" tall area. trying to see if theres something i can produce for the mm industry. Applications that I can think of at the moment are any kind of drilled/engraved/profiled plates, carb mount adapters, governor arm block off plugs, and im sure a thousand other things. Any suggestions appreciated. Custom milled name plates would be pretty cool too I thought. Oh and air cleaner adapters. Anything made outta billet always makes something look soo much better. ill post some pics after I produce a couple parts.
Wed Oct 13, 2010 11:06 pm |
Machine
Joined: Thu Jan 29, 2009 7:27 pm Posts: 273 Location: Malvern, Ar
 Re: CNC milled billet parts available soon
I'll be waiting.
_________________ 1554 excel- custom MB sport totin a stage II generac temporarily 20XRD Bullet- 300X Merc
Thu Oct 14, 2010 9:56 am |
jordy
Joined: Thu Mar 11, 2010 8:25 pm Posts: 1588 Location: South Louisiana
X2 ill be waiting also.
Thu Oct 14, 2010 10:51 am |
DMC
Joined: Sun Jan 25, 2009 7:23 pm Posts: 204 Location: Bayou House!
A billet cylinder block would be nice for starters!!!!!
Thu Oct 14, 2010 9:16 pm |
autogateman
Thu Oct 14, 2010 9:21 pm |
BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
Your gonna need a bigger CNC
Thu Oct 14, 2010 9:50 pm |
DMC
Thu Oct 14, 2010 9:52 pm |
autogateman
no its too large of a part.
Thu Oct 14, 2010 10:03 pm |
autogateman
some trick valve covers are prolly gonna be the first parts i produce for the mm's. i think that would do well
Thu Oct 14, 2010 10:05 pm |
DMC
Thu Oct 14, 2010 10:17 pm |
marshmaster
I'd make the billet carb spacer people sell them for around 75-100 bucks and it's a good way to play wit the stock carb I could send you a detailed spec sheet for the size and all dat good stuff or you could buy one and copy it I know alphacarts.com sells them
Thu Oct 14, 2010 10:39 pm |
BradS
We might need to talk about some contract work -- not sure if I wanna do it or not
You wouldnt happen to have a waterjet would ya?
Thu Oct 14, 2010 11:36 pm |
autogateman
Fri Oct 15, 2010 7:17 am |
Chico80x
Joined: Tue Aug 11, 2009 10:55 am Posts: 743 Location: Ft. Lauderdale, FL
You should try making a fuel pump block off cover and a governor lock. I think these parts in billet would like nice since they sit right on top of the motor and since they are small, they should be pretty easy for you to make.
In fact, if you make one, PM that I'll buy them off of you.
_________________ "We Are Products Of Our Decisions"
Fri Oct 15, 2010 8:20 am |
