CNC milled billet parts available soon https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=13072 |
Author: | autogateman [ Wed Oct 13, 2010 11:06 pm ] |
Post subject: | CNC milled billet parts available soon |
Hey guys, I just set up my shop with a CNC milling machine. I will be able to cut any 3D part that can fit into a 20" long by 5" deep by 10" tall area. trying to see if theres something i can produce for the mm industry. Applications that I can think of at the moment are any kind of drilled/engraved/profiled plates, carb mount adapters, governor arm block off plugs, and im sure a thousand other things. Any suggestions appreciated. Custom milled name plates would be pretty cool too I thought. Oh and air cleaner adapters. Anything made outta billet always makes something look soo much better. ill post some pics after I produce a couple parts. |
Author: | Machine [ Thu Oct 14, 2010 9:56 am ] |
Post subject: | Re: CNC milled billet parts available soon |
I'll be waiting. |
Author: | jordy [ Thu Oct 14, 2010 10:51 am ] |
X2 ill be waiting also. |
Author: | DMC [ Thu Oct 14, 2010 9:16 pm ] |
A billet cylinder block would be nice for starters!!!!! |
Author: | autogateman [ Thu Oct 14, 2010 9:21 pm ] |
Author: | BradS [ Thu Oct 14, 2010 9:50 pm ] |
Your gonna need a bigger CNC |
Author: | DMC [ Thu Oct 14, 2010 9:52 pm ] |
Author: | autogateman [ Thu Oct 14, 2010 10:03 pm ] |
no its too large of a part. |
Author: | autogateman [ Thu Oct 14, 2010 10:05 pm ] |
some trick valve covers are prolly gonna be the first parts i produce for the mm's. i think that would do well |
Author: | DMC [ Thu Oct 14, 2010 10:17 pm ] |
Author: | marshmaster [ Thu Oct 14, 2010 10:39 pm ] |
I'd make the billet carb spacer people sell them for around 75-100 bucks and it's a good way to play wit the stock carb I could send you a detailed spec sheet for the size and all dat good stuff or you could buy one and copy it I know alphacarts.com sells them |
Author: | BradS [ Thu Oct 14, 2010 11:36 pm ] |
We might need to talk about some contract work -- not sure if I wanna do it or not You wouldnt happen to have a waterjet would ya? |
Author: | autogateman [ Fri Oct 15, 2010 7:17 am ] |
Author: | Chico80x [ Fri Oct 15, 2010 8:20 am ] |
You should try making a fuel pump block off cover and a governor lock. I think these parts in billet would like nice since they sit right on top of the motor and since they are small, they should be pretty easy for you to make. In fact, if you make one, PM that I'll buy them off of you. |
