Gatortail trim https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=15401 |
Author: | Bayoucruiser [ Mon Jan 17, 2011 12:38 pm ] |
Post subject: | Gatortail trim |
Has anybody ever had problems with the trim unit on the gatortail? Whenever I trim it up and down as the shaft moves in and out of the unit it leaks fluid. I think a seal may be broken in the unit. Has anybody had this problem? |
Author: | dog walker [ Mon Jan 17, 2011 12:48 pm ] |
Post subject: | Re: Gatortail trim |
It happens,I had one that leaked a small amount of fluid for about two years and never had a problem with it. I just checked the fluid once in a while by topping it off. |
Author: | Gatorpoint [ Mon Jan 17, 2011 4:11 pm ] |
Yeah sounds like your seal is out. Contact Gatortail and they will get ya fixed up. |
Author: | POKER1 [ Mon Jan 17, 2011 4:38 pm ] |
Never looked close at a GT trim unit but typical hydrolic rams are all basically the same. Probably needs an O-ring changed. There are O-rings on the piston that make the seal. |
Author: | Tenpoint [ Mon Jan 17, 2011 6:10 pm ] |
Mine was leaking bad bout a month ago. Brought it to GT and they rebuilt the trim unit in about 30 minutes. Replaced the seal and changed out the ram itself. |
Author: | dozrya [ Mon Jan 17, 2011 8:14 pm ] |
Only issue I ever had with the trim was that it didnt work the other morning when it was 28 outside. Worked after I cranked the engine. Had to get the motor bracket off with my hammer. |
Author: | POKER1 [ Mon Jan 17, 2011 8:23 pm ] |
The piston could get damaged under extreem pressure but typically the seals will blow. Should be able to open it up with a spanner wrench and pull the piston out. Replace seals and your back in business. If you do it replace them all while you got it open. O-rings are cheap. |
Author: | LA Mudder [ Mon Jan 17, 2011 9:06 pm ] |
is this something all gtr's eventually end up doing or is it caused my something else like leaving it sit up for too long? |
Author: | craig [ Mon Jan 17, 2011 9:13 pm ] |
Author: | POKER1 [ Mon Jan 17, 2011 9:57 pm ] |
Author: | WestEndAngler [ Tue Jan 18, 2011 8:29 am ] |
Gator-Tail upgraded mine when I had them do my 100 hr service |
Author: | jordy [ Tue Jan 18, 2011 10:56 am ] |
i have 86 hrs on my motor and im on my 3rd trim.....some last longer than others....its completely normal. |
Author: | POKER1 [ Tue Jan 18, 2011 12:11 pm ] |
Author: | dog walker [ Tue Jan 18, 2011 12:25 pm ] |
Well I had around 600 hours on mine before the leak got real bad. It was just a small leak after about the second year I had it. You would never see it drip but I could see it on the transom. |
Author: | jordy [ Tue Jan 18, 2011 12:27 pm ] |
Author: | LA Mudder [ Tue Jan 18, 2011 2:29 pm ] |
I hear ya i got about 35 hrs on my motor and it dont leak yet but after a couple of days of sitting it dosent trim up like normal to get out of the bracket. |
Author: | dozrya [ Tue Jan 18, 2011 6:22 pm ] |
I think my issue was because of the cold weather. Have not had issues since. |
Author: | deltaduckmaster [ Tue Jan 18, 2011 6:46 pm ] |
The old one was the good ones. They had alum. housing with stainles ram.. The trim company changed it to alum. to alum to i guess make them cheaper.. Now they leak pretty easy when they do leak and gt get them they replace the alum with the stainles.. After that usally no more problem!! That is my take on it!! |
Author: | saveontaxes [ Wed Jan 19, 2011 6:56 am ] |
anybody got pic's of the trim unit they use? |
Author: | retired and broke [ Wed Jan 19, 2011 1:31 pm ] |
Seems like it is ok for a Gatortail to break, but not for any others to break. ![]() |
Author: | BROOKS [ Wed Jan 19, 2011 3:51 pm ] |
Author: | deltaduckmaster [ Wed Jan 19, 2011 6:08 pm ] |
Author: | Tenpoint [ Wed Jan 19, 2011 6:31 pm ] |
Author: | retired and broke [ Wed Jan 19, 2011 6:39 pm ] |
Author: | deltaduckmaster [ Wed Jan 19, 2011 7:33 pm ] |
Author: | saveontaxes [ Wed Jan 19, 2011 9:39 pm ] |
