fredbear012
 Need help!!
This past June i bought a brand new Alumacraft 15' by 60" rivited jon boat from academy, and was planning on putting a 27 hp prodrive on it. My question is does anyone have a similar set up, and if so will the boat handle such a motor? Seeing that it is a thinner grade of aluminum than the alweld boats. (can the Transom handle the torque?)
Thanks to all.
Mon Jan 31, 2011 7:57 pm |
HUNT4DEER
Joined: Sun Jan 03, 2010 10:39 am Posts: 833 Location: DODGIN ROCKS ON THE RIVER OR CARS ON THE INTERSTATE
 Re: Need help!!
got a rivited 14x48 with a 23 and its fine. 4 years now and no transom problems. it has alot to do with what you are going to do with the boat. shallow open water will be fine. if you put it in the mud, heavy veg or stumps and timber you may not hold up as well. i use mine in a river with gravel bars. most people run jets. ive hit a few rocks but no holes in the boat, very few dents. i dont have to work the motor alot so the transom doesnt get alot of abuse. if i was in the mud ide say ide have problems.
Mon Jan 31, 2011 8:06 pm |
texman034
 Re: Need help!!
_________________ Work harder --- Live better.
Mon Jan 31, 2011 8:18 pm |
fredbear012
 Re: Need help!!
Yea thats what i was thinking, but running it through lilly pads and moss i should be fine? i ask this because i will be running it in lake sommerville in texas and thats all that is there.
Mon Jan 31, 2011 8:24 pm |
UNCLE-J
 Re: Need help!!
Just have the transom braced up a bit more right now... It is only a 100 dollars or so.. Better safe than sorry
Mon Jan 31, 2011 8:26 pm |
fredbear012
 Re: Need help!!
ok. and is a prodrive my best bet?, im new at this and im 17 so its kind of a learn from trial and era thing. but appreciate any advise i can get.....
Mon Jan 31, 2011 8:31 pm |
UNCLE-J
 Re: Need help!!
Mon Jan 31, 2011 8:32 pm |
fredbear012
 Re: Need help!!
ok thanks to all
Mon Jan 31, 2011 8:36 pm |
TOWBOATER
 Re: Need help!!
You might put a tape on that boat ,because I used to have an alumacraft that I bought from academy,and it wasnt near that wide.But then again I might be wrong.I just never seen academy carry a boat of that size. my boat was a 15/48
Mon Jan 31, 2011 10:36 pm |
fredbear012
 Re: Need help!!
lol yea after i put that i pulled out my papers and it said its 48" wide.
Tue Feb 01, 2011 8:01 am |
Woodiebuster
 Re: Need help!!
You measure the width at the bottom, the top width all matters on how the boat was crimped.
Tue Feb 01, 2011 4:23 pm |
fredbear012
 Re: Need help!!
Im pretty sure that the top is 60 ill have to take a tape to it though not for sure.
Tue Feb 01, 2011 7:45 pm |
HUNT4DEER
 Re: Need help!!
on a 16x48 the 48 is at the bottom. the beam is at the top or widest spot. the bottom is what matters. when you see someone talk about a 16x48 or what ever x what ever the bottom is the important part.
Tue Feb 01, 2011 8:11 pm |
