Pd vs. Mb https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=15750 |
Author: | fredbear012 [ Tue Feb 01, 2011 10:04 am ] |
Post subject: | Pd vs. Mb |
What is the better motor to push my 15'x48" alumacraft? A pd 27hp or a mb 23 mini lite? What's the pros and cons. |
Author: | bpurvis [ Tue Feb 01, 2011 10:25 am ] |
Post subject: | Re: Pd vs. Mb |
PD..... no contest ![]() |
Author: | Brasso [ Tue Feb 01, 2011 12:50 pm ] |
It's all on the conditions you run. The pro drive will run a little faster, and handles better, but may not go through as much due to it not having as long a tail as the mud buddy. |
Author: | Gigafowl [ Tue Feb 01, 2011 12:58 pm ] |
The MB is lighter and won't wreck the hull as fast as the PD..... But if you put either one on the hull won't last but a few seasons if you do much trailering and actual mud and stump running.... |
Author: | Chico80x [ Tue Feb 01, 2011 1:13 pm ] |
I bought a new mud buddy 5500 this past September and put 50 hours on it during duck season. I haven't had a bit of trouble with it and my friend is nearing 100 hours on a stock 35 and hasn't had any issues with it either. If you look around, you'll see a few guys on here have had problems with the PD gear cases which makes me think that the MB belt system is a lot easier to maintain and fix. |
Author: | fredbear012 [ Tue Feb 01, 2011 1:18 pm ] |
I'm having my transom re braced by a friend if that's what you meAn by wreck your hull? |
Author: | quackconsumer [ Tue Feb 01, 2011 1:26 pm ] |
Author: | Chico80x [ Tue Feb 01, 2011 1:29 pm ] |
Author: | Woodiebuster [ Tue Feb 01, 2011 4:16 pm ] |
Gears have proven themselves as the best option in the automobile world. I imagine it would be easier to n!gger rig a belt drive to hobble back to the ramp though... Maybe wrap an anchor line around the pulleys.. |
Author: | HUNT4DEER [ Tue Feb 01, 2011 4:22 pm ] |
yah that will work?????????????????????????????????????? no it wont! |
Author: | quackconsumer [ Tue Feb 01, 2011 5:47 pm ] |
Author: | POKER1 [ Tue Feb 01, 2011 5:55 pm ] |
Author: | Woodiebuster [ Tue Feb 01, 2011 6:22 pm ] |
I knew somebody would bring up the alternator belt, your right.. things are different on cars and boats. They have been runnin gears on outboards for years and pro-drive just adapted it to a shallow water application. A belt drive does a great job doin the same thing. I was just sayin gear drives have proven themselves strong and effective in many applications. |
Author: | HUNT4DEER [ Tue Feb 01, 2011 6:59 pm ] |
i think the belt has some shock absorbing effect on a prop strike. ive never run a pd so i dont know about vibration in the sitck but ide think the belt would help there also. as for outboards and gears that is the week link when it comes to prop strikes. im seeing pd with broken gears, broken housings. when that prop stops something has to give. its going to stop the motor, shear the teeth off a gear or seaperate the mesh of the gears ie the housing will give and crack. there is a fine line between so strong that i wont brake and it being light enough to put into service. you could put dozer parts on a pd and never brake them. you couldnt float it, but you couldnt brake it. that being said pd has a following. they are or seem to be at the top. pd wouldnt be there if it wasnt a good motor. if these brakes were a major problem pd wouldnt last. it seems to be reoccurring as thay have had several design changes in that area of the motor. who knows? |
Author: | POKER1 [ Tue Feb 01, 2011 7:11 pm ] |
Where are you seeing all these broke PDs? I don't see them breaking any more often than any of the other brands and they are all running belts. |
Author: | HUNT4DEER [ Tue Feb 01, 2011 7:19 pm ] |
over on props section. lot of talk on the subject. ive seen it here before several times. |
Author: | Brasso [ Tue Feb 01, 2011 8:13 pm ] |
There both really good motors. I prefer pro drive because of how awsome they drive, but then again vie never driven a mud buddy. Just pick what you think is best and what suits you best and be happy with it and call it a day. That's all you can do. With that being said.. It's rare that you go wrong with a pd!! |
Author: | take'emgator [ Tue Feb 01, 2011 8:22 pm ] |
Buy what you want, look at it this way if you don't end up liking it i promise you can sell it and then try anouther brand, but don't let the hype about one motor over another influence you cause you might buy something you end up not liking! |
Author: | quackconsumer [ Tue Feb 01, 2011 8:43 pm ] |
Anyone who buys a motor based on what they read on da internet deserves whatever piece of crap they may end up wit. Test Drive.... Test Drive.... TEST DRIVE. |
Author: | take'emgator [ Tue Feb 01, 2011 8:45 pm ] |
I think thats what i just said JC, lol. |
Author: | HUNT4DEER [ Tue Feb 01, 2011 8:47 pm ] |
none of them are crap |
Author: | Brasso [ Tue Feb 01, 2011 10:54 pm ] |
Actually.. In the end everythings a piece of crap lol |
Author: | quackconsumer [ Wed Feb 02, 2011 5:53 am ] |
Author: | quackconsumer [ Wed Feb 02, 2011 5:56 am ] |
Author: | idabilly [ Wed Feb 02, 2011 7:35 pm ] |
I have owned five Mudbuddy Hyperdrives and have owned / run a Prodrive for the last two seasons. I subject the PD to the same hard use I put my Hypers through and it has not let me down. This thread is full of opinions from people who have not owned both and are basing their comments on hearsay and not direct experience. Let's give it a break. None of these motors are bombproof and all are built in very robust fashion for the torture we put them through. |
Author: | Chico80x [ Wed Feb 02, 2011 9:23 pm ] |
Author: | take'emgator [ Wed Feb 02, 2011 10:32 pm ] |
Author: | craig [ Thu Feb 03, 2011 7:47 am ] |
Author: | Chico80x [ Thu Feb 03, 2011 10:21 am ] |
