Need Help!
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=16120
Author:  Duck Slayer 27 [ Sun Feb 13, 2011 4:30 pm ]
Post subject:  Need Help!
How can you get the prop of a GDSD that is a little rusted on? im new at this and have no clue how to do it?
Author:  TURBODRIVE [ Sun Feb 13, 2011 4:39 pm ]
Post subject:  Re: Need Help!
im suprised Giga aint jumped on this
Author:  WestEndAngler [ Sun Feb 13, 2011 5:02 pm ]
2x4 and you chalk it up I believe he's posted about it before...
Author:  marsh maniac [ Sun Feb 13, 2011 7:07 pm ]
clean the rust off. coarse steel wool might work. wrap enough steel wool around a drill bit to create a somewhat snug fit in the hub of the prop. then let the drill do the work.
fyi - I don't have a surface drive and don't know how the prop attaches to the shaft on a gdsd, but just trying to give you some ideas.
Author:  marsh maniac [ Sun Feb 13, 2011 7:09 pm ]
are you trying to remove the prop or put it on?
Author:  GREENMOCCASIN09 [ Sun Feb 13, 2011 9:07 pm ]
you might have to heat the hub of the prop up w/ a tourch the pretty much just beat it off w/ a hammer . Then put a lot of never seize/pipe dope/copper kote then screw the new prop on after the threads are clean w/ a wire brush the never-seize is on.
good luck
Author:  garrettpearce [ Sun Feb 13, 2011 10:32 pm ]
heating prop may mean new seals.
Author:  cb5331 [ Sun Feb 13, 2011 10:33 pm ]
Get some dry ice..or nitrogen
Author:  take'emgator [ Sun Feb 13, 2011 10:35 pm ]
Was just thinking that Garrett, had to do it to my old LT but it was the only way to get the prop off, ended up replacing seals. I always use to pull the prop off and clean it about every 4-6 runs jsut to keep it clean
Author:  garrettpearce [ Sun Feb 13, 2011 10:42 pm ]
may have to fab a piece of alum 3''x1/2''x3' with hole big enough to go over shaft at the end and bind it against prop to unscrew it. works for prodrive
Author:  LA Mudder [ Mon Feb 14, 2011 2:31 pm ]
where u located duck slayer?
