Mounting battery under extended deck
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=1661
Author:  GaugeTheDuckDog [ Sat Apr 18, 2009 9:53 pm ]
Post subject:  Mounting battery under extended deck
Is it worth the time and money to put the battery from the back to the front. Were do you get the cable to run from the motor to the battery. Do you run dual batterys?
Author:  deadbird8 [ Sun Apr 19, 2009 5:40 am ]
Post subject:  Re: Mounting battery under extended deck
Depends on what you are trying to do. It works well for different weight distribution if you need to move it.
There are lots of options for the long cable. You want one that is large enough to handle the cranking amps and flexible to not interfere with the motor operation.
I ended up buying a 4 guage 20' from Gator Trax. It was a pretty reasonable price. You can make one with welding cable or possibly jumper cables but you need to ensure the lugs are on them very well (mine failed and I ended up buying one).
