atlong
Joined: Tue Dec 21, 2010 4:32 pm Posts: 94 Location: Starkville, MS
 Making a grab, need some advice
hey guys im gonna be making a grab bar for my boat within a week or so and just wanting to get yalls opinion on my idea and ways to make it better. i was thinking of making the bar out of 1/2in emt bent in a C shape like most grab bars. for the base i was just gonna get some thin sheet metal and weld 2 3/8 pieces of emt to it so the bar will slid over them, then drill two holes and use some pins to hold it in place. this would allow the bar to be taken out when hunting or fishing. how does this sound? if anyone else has made one and made it differently id like to get some ideas from yall. thanks guys
_________________ Don't Tread on Me
Thu Mar 10, 2011 8:48 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 Re: Making a grab, need some advice
, 1/2 inch emt is not gonna be strong at all. youre gonna bend it over the first time you really pull on it
Thu Mar 10, 2011 8:58 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
1/2" EMT? Sounds like ya gonna bust ya azz, that's how it sounds.  Ya better make it outta something stronger than that for sure. More along the lines of 3/4" or 1" aluminum pipe. Even 1-1/2" aluminum conduit will bend very easily, & that's the last thing ya want your grab bar to do. This is one project ya don't want to skimp on, unless ya like bustin ya azz.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Thu Mar 10, 2011 9:01 pm |
atlong
thats exactly why i posted this hahaha. thanks for the input. camo so you think if i do 1 in aluminum pipe for the bar and 3/4 for the mount it would be rigid enough. does the idea itself sound good though?
Thu Mar 10, 2011 9:33 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
I've used 1" emt and it worked pretty good but it was on my gunbox so it was only about 20" tall. Plus emt will rust
Thu Mar 10, 2011 9:37 pm |
Team Camo
I'd use 1" for the grab bar & weld (2) 6" tall pices of 1-1/4" to the floor to insert it into & pin it like ya said.
Thu Mar 10, 2011 9:41 pm |
atlong
Thu Mar 10, 2011 9:57 pm |
Team Camo
Make it a comfortable height for you when standing up. Steel pipe is gonna rust, but that would probably work.
Thu Mar 10, 2011 10:05 pm |
atlong
Thu Mar 10, 2011 10:09 pm |
dfou
Use emt from lowes. It's steel and galvanized so it helps with the rust issue
Thu Mar 10, 2011 10:18 pm |
atlong
Fri Mar 11, 2011 12:24 pm |
Team Camo
1" aluminum pipe bent around a 14" car wheel.
Fri Mar 11, 2011 3:14 pm |
dylndaw
Joined: Sun Feb 08, 2009 3:15 pm Posts: 117 Location: Prairieville,LA.
Fri Mar 11, 2011 7:50 pm |
atlong
Fri Mar 11, 2011 8:39 pm |
Team Camo
Yep
Fri Mar 11, 2011 9:57 pm |
