It is currently Sun Jul 27, 2025 4:49 pm
Reply to topic  [ 4 posts ]
 I'm sure this topic has been beat into the ground but...
Post I'm sure this topic has been beat into the ground but...
I am in the process of building my own longtail. I have owned 2 different longtails (GD and a MB, 9hp and 13 hp)prior to this one and sold them both. Both times I was convinced the area I was planning on hunting I wouldn't need one. Now I am back to square one hunting wild rice and cussing at my outboard. I never looked too hard at their construction. I am a decent welder and fabricator, but am having difficulty designing a water tight seal system. Any thoughts, plans, etc...? I can tell you I plan on using a 3/4" shaft with a 1" housing unless someone chimes in w/ a better suggestion.
New to the forum, never was aware it existed. Awesome website and sounds like most have a great wealth of knowledge. Comments/suggestions appreciated.
Fallen Skies Strait Meat Duck Club......when limits just aren't really your thing
Mon Mar 28, 2011 5:01 pm
Post Re: I'm sure this topic has been beat into the ground but...
they make a seal thats for 1in housing and 3/4 bore, i used them on mine put three on each end so wont have to worry bout water getting in, just make sure you get 1 inch seamless tubing
Mon Mar 28, 2011 7:19 pm
That was kind of my line of thought as well. How many bearings did you put in then? I am planning on using a 72" shaft.
Tue Mar 29, 2011 6:02 am
3 bushings, middle is strictly for shaft whip. a bearing at the top is good also
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Tue Mar 29, 2011 1:50 pm
Users browsing this forum: No registered users and 127 guests
