It is currently Tue Aug 05, 2025 12:20 am
Reply to topic  [ 10 posts ]
 FLEXSTEEL APOXY?
Post FLEXSTEEL APOXY?
Does anyone have any info,or opinions on STEELFLEX Apoxy?
Web address?
Weight gain-problems?
Can I apply it myself ?
Cost /gallon? How many gallons for bottom of boat?
17x48 EXCELL/36PD
Mon Apr 27, 2009 8:15 pm
Post Re: FLEXSTEEL APOXY?
http://www.fascoepoxies.com/
Roll it on after prep. About 100.00 or so per gl. 9x-2000 is the one you want. Weight would not be much.
18x48 Charles Leonard / 36PD
Mon Apr 27, 2009 8:51 pm
Weight would be less than a couple pounds, depending on how many coats you do.
I coated a 17' & 18' boat with one gallon of end product (half gal of each part).
Scuffed the bottom of the hull with a sander, like 80 or 100 grit.
Clean with whatever fasco says to use to clean/prep the surface.
The warmer it is, the faster it cures!!
Mix that stuff good, then real good, then again for good measure.
I did the boats in thirds, just poured it outa the bucket, then spread it around via the roller.
It does chip on rocks really easy, but does help sliding over logs & weeds!
Tue Apr 28, 2009 6:40 am
floral city airboats sells frog spit
1-352-637-4390
........average white boy just trying to get by!!!!
Tue Apr 28, 2009 8:03 am
I had the Steelflex on my last hull. It does come off easily on rocks, BUT if you have some hooks it will fill them in nicely.
Aucoin... what is the difference between the frog spit and SF? About the same stuff? I have heard of it for a while but I have never seen it on a hull...
Wonder which is better...
Tue Apr 28, 2009 9:19 am
Thanks for all the input!
One more question.
It sounds like it really makes the hull slick, which I know is the objective,
but does it cause any problems. like sliding out in turns or any other problems.
l
17x48 EXCELL/36PD
Tue Apr 28, 2009 4:00 pm
one potential problem...
Dont unhook your boat from the trailer until you are in the water, it WILL slide off a lot easier.
Wed Apr 29, 2009 8:31 am
stanco, not sure on the difference between the two, and they around the same price also. i ordered a gallon and it was like $110 after shipping.
Wed Apr 29, 2009 10:55 am
Hey I`ve got another question. I called to late to order that Flexsteel.or ask them a question. So here it is. What about color, is it clear, or do you add color to it or do you paint it, or does it come a certain color?
17x48 EXCELL/36PD
Sat May 02, 2009 7:20 pm
It can be tinted different colors. Tell them what color you want when ordering.
Sat May 02, 2009 7:37 pm
Users browsing this forum: No registered users and 93 guests
