It is currently Sun Jul 27, 2025 12:58 pm
Reply to topic  [ 10 posts ]
 Just ordered 1st SD....need info on getting transom upto par
Post Just ordered 1st SD....need info on getting transom upto par
After more than 6 months of reading everyone's post and quite a bit of pm's assuring me to go big I just purchased a 35 GDSD!
Although, when I called to order the gal asked me the size of my boat and when I said a 1648 she cautioned me of the weight of these motors thinking a 27 might be a better option.
I just went ahead and got the big boy and figure I can upgrade to a mud hull in a few years! It's going on an '07 Weldbilt and want to ensure the transom is alright!
2011 35 GDSD pushing 1844 Go-Devil Hull
Mon May 23, 2011 1:56 pm
Post Re: Just ordered.....
Alot of people run 35's on 16x48 hulls without a problem. Just need to be sure the transom can handle the abuse.
Congrats on your purchase
Mon May 23, 2011 2:04 pm
Its a 2007 boat with little use.....I don't run true mud like you guys in LA or TX at all. I mainly got it for piece of mind in case of the occasional stump or submerged logs.
Any tips on beefing up my transom without a certified boat welder or anything??? I've seen where some guys without mud hulls have added a thick sheet of metal or even a 2x6 across where they bolt it to the transom.
Thanks in advance for any tips!
Casey
Mon May 23, 2011 2:15 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon May 23, 2011 5:29 pm
Congrats on the motor, now comes the world of mods. :twisted:
Mon May 23, 2011 5:37 pm
Mon May 23, 2011 5:43 pm
If you have access to a welder I'd put in a couple of knee braces on each side of the motor to take some of the flex out.
Mon May 23, 2011 6:03 pm
Post Re: Just ordered.....first SD....need some how to on transom
Tue May 24, 2011 9:29 am
Post Re: Just ordered 1st SD....need info on getting transom upto
If possible, get him to add a 3/16 or 1/4 alum plate about 12x12 on the outside of the transom & another one on the inside about 6x12. Also just have some gusset supports from the rear cross brace to the transom welded in. That should be overkill for it, but you won't have to worry about it anymore.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue May 24, 2011 4:44 pm
Tue May 24, 2011 9:43 pm
Users browsing this forum: No registered users and 189 guests
