Hydro-Turf
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=19430
Author:  Garland [ Tue Jun 21, 2011 11:49 am ]
Post subject:  Hydro-Turf
When installing Hydro Turf with the 3M backing is it strong enough to hold up. Do I need to put any other adhesive down. (I searched the forum and could not find anything on this.)
Author:  autogateman [ Tue Jun 21, 2011 12:04 pm ]
Post subject:  Re: Hydro-Turf
no, i used the 3m and it is incredibly strong. i had to remove a square of it later to install a seat base and i actually had to chip it off.
Author:  WestEndAngler [ Tue Jun 21, 2011 1:35 pm ]
x2 tough stuff!
Author:  1st-n-last59 [ Sun Jun 26, 2011 6:15 pm ]
U can u the 3m spray adhesive to help keep the edges down
Author:  Christop73 [ Sun Jun 26, 2011 8:17 pm ]
The 3m backing is all you will need, once it's down it ain't coming back up.
Author:  Fishoholic [ Tue Jul 05, 2011 12:54 pm ]
Where do you get the 3m spray adhesive
Author:  caddobrook [ Tue Jul 05, 2011 1:05 pm ]
3m spray adhesive can be bought at lowe's/home depot/walmart etc... (although I seem to recall that one of them only carries a proprietary brand now)..
But he is talking about a 3M backing that comes on hydro turf as an option. You can buy it with or without the 3m adhesive backing (better than the spray can ).
Best two options are get the 3m backing that comes on it (they charge you extra for it) or use contact cement.
3m spray adhesive will work but probably not your best option.
Author:  CaptCameltoe [ Tue Jul 05, 2011 9:17 pm ]
Look into a product called Seadek also. http://www.seadek.com/ I have seen this on flats boats in s fl and got the samples, pretty nice stuff.
Author:  HUNT4DEER [ Wed Jul 06, 2011 7:08 am ]
liquid nails makes a product in a brush or roll on that works very well. i used it on the carpet in my boat. its alot stronger than contact cement. as for the 3m spray they have 2 types. one is the regular the other is stronger gray can if i remember. it is better. i would clean the surface very well before i used the the 3m or contact cement. in the past they dont seem to grab as well as i would have liked. now the liquid nails stuff is very strong its a little thicker than contact cement. also around the edge i used regular liquid nails to keep it from rolling up. it grabbed almost instantly. in the past thats where ive found the problem, the field never seems to let go but the edges will.
Author:  muddawgchuck [ Wed Jul 06, 2011 7:47 am ]
Would a person have to sand up the non skid paint first to get it to stick?
Author:  HUNT4DEER [ Wed Jul 06, 2011 8:08 am ]
it would help. at least it would even out the surface so everything would stick with no high and low spots.
Author:  muddawgchuck [ Wed Jul 06, 2011 9:41 am ]
ok cool just wondering
Author:  MudGator [ Fri Jul 08, 2011 6:20 pm ]
will the hydro-turf adhere with spray adhesive. i want to install the stuff, but have the spray-in liner.
Author:  dixieduckslayer [ Sat Jul 09, 2011 7:46 am ]
sandpaper to get the nonskid off? or angle buffer? any suggs.?
Author:  T-Bubba [ Sat Jul 09, 2011 7:51 am ]
try a wire wheel or a 80 grit flapper wheel on a 4" grinder... will scuff it up good
