It is currently Tue Aug 05, 2025 4:52 am
Reply to topic  [ 12 posts ]
 Hyd. Trim on PD
Post Hyd. Trim on PD
Is there a fuse somewhere on the trim? Mine just decided to stop workin.
I have 2 switches and changed em out and neither one of them worked.
Sat May 30, 2009 4:12 pm
Post Re: Hyd. Trim on PD
Check the 3 wires going into the motor.
Sat May 30, 2009 6:00 pm
I took my test light and tested for constant power and had it. Pushed up on the switch and the top post got hot. Pushed down on the switch and the bottom post got hot. Checked the 3 wires going into the motor and the black had no power (didnt think it would but I checked) On the other 2 when I pushed the switch up one had power and when I pushed the switch down the other had power.
Im thinking the pump is bad.
Any other ideas? Is there a reset on the motor somewhere?
Sat May 30, 2009 6:40 pm
Check the wires where they go into the trim motor. Mine went out due to a wire break right at the pump. Wires were a little to short and the constant pulling on the wires finally did them in. PD rewired the pump with long leads and no more trouble. Wire actually broke inside the rubber gromet in the housing.
18x48 Charles Leonard / 36PD
Sat May 30, 2009 10:34 pm
The looks fine. Sucks cause I was gonna go for a ride today for the 1st time in a while.
Oh well, Ill just go for a ride when I get home from work in 2 weeks.
Sun May 31, 2009 4:59 am
Sounds like da motor for your hydrolics is bad.
Sun May 31, 2009 5:28 am
Sun May 31, 2009 8:54 am
Yea what he said ^
Sun May 31, 2009 10:33 am
Why could you not still ride? If the hydraulics go out does the ratchet thing not work either? :?:
Sun May 31, 2009 9:51 pm
Sun May 31, 2009 9:57 pm
Eh Its at Pro Drive now.
I bet it works when I get it back :mrgreen:
Mon Jun 01, 2009 7:37 am
Mon Jun 01, 2009 3:44 pm
Users browsing this forum: No registered users and 101 guests
