Problem with truck https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=24761 |
Author: | QuackStacker5253 [ Thu Dec 08, 2011 9:12 pm ] |
Post subject: | Problem with truck |
I noticed yesterday my oil pressure was higher than usual, since then everytime I crank my truck the oil pressure increases and is now past the last number (80). Y'all think this would be the sender goin out or the excess pressure valve stuck? I'm leaning more towards the sender because the guage shows the pressure being high before even cranking the truck. Just wanted a few extra opinions. Thanks, Jake |
Author: | take'emgator [ Thu Dec 08, 2011 9:21 pm ] |
Post subject: | Re: Problem with truck |
more than likely the sending unit, i would start there |
Author: | shallow water master [ Thu Dec 08, 2011 9:35 pm ] |
what kind of truck is it ??? if it a Chevy the dash is most of the time the problem |
Author: | QuackStacker5253 [ Thu Dec 08, 2011 9:55 pm ] |
It's a Chevy (avalanche). By dash do you mean something with the guage itself or the sender? |
Author: | MaXXis85 [ Fri Dec 09, 2011 7:05 am ] |
First off Oil Pressure is the resistance to flow. THe colder it is the Harder it is to flow. Now that you know this Lets get on topic of your Chevy Avalanche. It is probably a bad sending unit or bad cluster. What year? |
Author: | krogers [ Fri Dec 09, 2011 9:05 am ] |
Check the cluster. GM's are famous for bad clusters. i have a 04' dmax and 06 Z and both had bad clusters. |
Author: | postalpaul [ Fri Dec 09, 2011 9:40 am ] |
http://www.modulemaster.com/en/index.php Sent mine here lifetime warranty |
Author: | QuackStacker5253 [ Fri Dec 09, 2011 12:44 pm ] |
It's an 04 avalanche, and the pressure is showin all the way topped out and it's runnin fine so I'm guessin it's te sendin unit. |
Author: | WestEndAngler [ Fri Dec 09, 2011 1:12 pm ] |
Mine just went out in my 07 Tahoe... It actually shut the engine down every 150 miles to low RPM. It was sending codes & freaking out... I ended up taking it to the dealer & said F it lol |
Author: | shallow water master [ Fri Dec 09, 2011 11:02 pm ] |
gauge itself and yes it going to go up some when it get colder but it shouldn't be that much |
Author: | sela_native [ Sat Dec 10, 2011 9:38 pm ] |
had this happen to my 06 chevy truck, running down the interstate BAM pinged out oil pressure, talk about shit a brick. got off work picked up a new oil pressure sending unit (back of block) replaced and hour later back up and running at normal range. |
