It is currently Mon Jul 28, 2025 8:39 am
[ 8 posts ] |
Tex79
 Camo stencils ??
Any of you guys paint your boat using a stencil? I bought a set of duck grass stencils off e bay. Today I tried to start on my boat but was having problems getting the stencil to lay down flat around the rib running down the side of my boat, I wasn't happy with the way it looked and ended up wiping off the small section that I did paint with some acetone. So my question is does anyone have any tips or tricks that I could use to help with this? How can I hold the stencil in place while I spray it? Any help is greatly appreciated. And thank you in advance.
Sat May 12, 2012 7:41 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Camo stencils ??
Easiest way is with the motor off & the boat upside down, but with the help of some stencil adhesive, it's not too bad to do it by yourself with it on the trailer. Spray a light coat of adhesive on the back of the stencil to help hold it in place.
Another trick is to use several different colors, overlapping them so it looks more like real grass, & also helps to hide where the stencil isn't tight up against the boat.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Sat May 12, 2012 7:45 pm |
CAJUN OUTLAW
you will need 4 hands and a wire coat hanger.
Sat May 12, 2012 8:28 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Re: Re: Camo stencils ??
_________________ 1850 & 36pd
Sat May 12, 2012 8:43 pm |
OwenDickeson
 Camo stencils ??
All you need is stencil adhesive and a little patience.
Tex79
 Camo stencils ??
Thanks a lot guys, I didn't even know there was such a thing as stencil adhesive I guess I'll have to get some. Any certain brand I should look for or are they all about the same?
Sat May 12, 2012 9:36 pm |
med
Go to a craft shop like hobby lobby. There are many different kinds of spray adhesive but the kind that says for stencil use will have more tack. You will end up spraying less and have less build up on your stencil. Just mist the back and wait a few seconds before applying. It will be your best friend.
Sat May 12, 2012 9:52 pm |
Tex79
 Camo stencils ??
Thanks guys. I found some stencil adhesive today so I'll try this again on my next day off and hopefully have better results
Sun May 13, 2012 1:45 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 115 guests |
